X Klass - Xtream Codes IPTV Player (new)
afat45
SW FEED HUNTER
SW FEED HUNTER
Has thanked: 7 times
Been thanked: 28 times
Turkey
Aug 2024 25 13:13
Post by afat45
V 1.11 - 25/08/2024 :face with monocle:
This plugin is a rework of my XStreamity plugin but with all new layout and new side menu accessible by the "Menu" button.
:beer1: https://paypal.me/kiddac :beer1: or :hot beverage: https://ko-fi.com/kiddac :hot beverage:
Feeds are sometimes a little behind. (note this is a brand new plugin - feeds will catchup)
openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies. (Xstreamity plugin in feeds will also load the dependencies)
Dreamboxes - python3
enigma2-plugin-extensions-xklass_1.11_20240825_all.deb.rar
(5.1 MiB) Downloaded 21 times
enigma2-plugin-extensions-xklass_1.11.20240825_all.rar
(5.34 MiB) Downloaded 21 times
afat45
SW FEED HUNTER
SW FEED HUNTER
Turkey
Aug 2024 26 05:07
Re: X Klass - Xtream Codes IPTV Player (new)
Post by afat45
V 1.12 - 25/08/2024
enigma2-plugin-extensions-xklass_1.12_20240825_all.deb.rar
enigma2-plugin-extensions-xklass_1.12.20240825_all.rar
(5.35 MiB) Downloaded 22 times
Has thanked: 76 times
Sep 2024 08 14:17
Post by ocean777
V 1.13 - 08/09/2024
enigma2-plugin-extensions-xklass_1.13.20240908_all.rar
(5.35 MiB) Downloaded 16 times
Sep 2024 15 04:41
Post by ocean777
V 1.14 - 14/09/2024
tnx KiddaC
enigma2-plugin-extensions-xklass_1.14.20240915_all.rar
(5.37 MiB) Downloaded 17 times
Has thanked: 9 times
Been thanked: 152 times
Sep 2024 15 10:29
Post by Hannibal_Lecter
V 1.15 - 15/09/2024
enigma2-plugin-extensions-xklass_1.15_20240915_all.deb
(5.11 MiB) Downloaded 14 times
enigma2-plugin-extensions-xklass_1.15.20240915_all.ipk
(5.37 MiB) Downloaded 13 times
Sep 2024 23 15:32
XKlass v1.16
updt_21-09-2024
Redirect fixes
Expired line crash fix
Greece, Italy, Portugal Language transaltion updates
enigma2-plugin-extensions-xklass_1.16_20240921_all.deb
(5.11 MiB) Downloaded 12 times
enigma2-plugin-extensions-xklass_1.16.20240921_all.ipk
(5.37 MiB) Downloaded 16 times
Sep 2024 27 05:36
XKlass v1.17
I think I have fixed that tmdb variable crash
Also added in a few more amends for stripping out of some prefixes to help names work better with tmdb searching
enigma2-plugin-extensions-xklass_1.17_20240926_all.deb
(5.11 MiB) Downloaded 17 times
enigma2-plugin-extensions-xklass_1.17.20240926_all.ipk
afat45
SW FEED HUNTER
SW FEED HUNTER
Turkey
Oct 2024 31 04:59
Post by afat45
V 1.18 - 30/10/2024 :face with monocle:
enigma2-plugin-extensions-xklass_1.18_20241030_all.deb.rar
(5.11 MiB) Downloaded 8 times
enigma2-plugin-extensions-xklass_1.18.20241030_all.rar
(5.37 MiB) Downloaded 12 times
Nov 2024 13 06:48
The Final Frontier
v. 1.19 - 12.11.2024
VOD - IMDB plugin - name and prefix stripping for better results
German translation update
thx@ KiddaC
enigma2-plugin-extensions-xklass_1.19.20241112_all.ipk
https://fastupload.io/673345c010ff3387
enigma2-plugin-extensions-xklass_1.19_2024112_all.deb
https://fastupload.io/2c6e9d18cee75231
Nov 2024 14 06:35
The Final Frontier
XKlass _v. 1.20 _13.11.2024
enigma2-plugin-extensions-xklass_1.20.20241113_all.ipk
https://fastupload.io/db15fd6c3df43fca
enigma2-plugin-extensions-xklass_1.20_2024113_all.deb
https://fastupload.io/165e6eae6e43f9be
