Levi45 plugins update monitoring
- Has thanked: 6 times
- Been thanked: 94 times
24
13:18
levi45 Addons Panel UPDATE 24-07-2024
enigma2-plugin-extensions-mmpicons_1.4_all.ipk
enigma2-plugin-extensions-xklass_1.08.20240723_all.ipk
enigma2-plugin-skins-aglare-fhd_3.8_all.ipk
enigma2-plugin-skins-maxy-fhd_1.1_all.ipk
enigma2-plugin-extensions-mmpicons_1.4_all.deb
enigma2-plugin-extensions-xklass_1.08_20240723_all.deb
Please use only "Like button", no need to write thanks
27
11:06
levi45 Addons Panel UPDATE 26-07-2024
enigma2-plugin-extensions-hdfradio_2.11.2_py2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py2_cortexa9hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.11.2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.11.2_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.11.2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.11.2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.12_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.12_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.12_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.12_mips32el.ipk
enigma2-plugin-extensions-xklass_1.10.20240726_all.ipk
enigma2-plugin-extensions-youtube_h1-git1221-7b30012-r0.0.ipk
enigma2-plugin-extensions-youtube_py3-git1221-7b30012-r0.0.ipk
skins-metrixfhd-neo_oatv_V.7s_r5_all.ipk
enigma2-plugin-extensions-xklass_1.10_20240726_all.deb
30
06:34
levi45 Addons Panel UPDATE 29-07-2024
enigma2-channellist-vhannibal-motor_29-07-2024_all.ipk
enigma2-channellist-vhannibal-motor-icam-levi45-mod_29-07-2024_all.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py2_cortexa9hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.11.2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.11.2_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.11.2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.11.2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.12_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.12_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.12_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.12_mips32el.ipk
enigma2-plugin-extensions-eventdatamanager_all_v1.0-r20_.deb
- Been thanked: 289 times
31
05:57
Re: Levi45 plugins update monitoring
enigma2-plugin-extensions-levi45multicammanager_10.1-r23_all
Ipk/Deb file added, after installation if the plugin not showing in the plugin menu then please give this command
if you image is pyhon 3.xx then
if you image is python 2.xx then
Soon will be new release 10.1-r24
what's new
Cleaned unnecessary codes
Changed way that online update done(instead of auto update now you can update via pressing info and then yellow button to update ,if there is any newer version available)
Now you can remove installed cam, via Levi45 Multicam Manager , Cam Download (yellow button)
To install use command below :
wget -q "--no-check-certificate" https://raw.githubusercontent.com/levi- ... staller.sh -O - | /bin/sh
what's new
- enigma2-plugin-extensions-levi45multicammanager_10.1-r23_all.ipk
- (978.92 KiB) Downloaded 33 times
- enigma2-plugin-extensions-levi45multicammanager_10.1-r23_all.deb
- (914.82 KiB) Downloaded 29 times
06
16:34
levi45 Addons Panel UPDATE 06-08-2024
enigma2-channellist-ciefp-vod-motor_05-08-2024_all.ipk
enigma2-plugin-extensions-coolextra_1.2_all.ipk
enigma2-plugin-extensions-linuxsat-panel_2.0_all.ipk
enigma2-plugin-extensions-piconremover_0.1-r1-20240806_all.ipk
enigma2-plugin-extensions-simple-zoom-panel_2.1.0_all.ipk
enigma2-plugin-extensions-linuxsat-panel_2.0_all.deb
07
14:32
levi45 Addons Panel UPDATE 07-08-2024
enigma2-channellist-mohamedos-motor_07-08-2024_all.ipk
enigma2-plugin-extensions-levi45multicammanager_10.1-r26_all.ipk
enigma2-plugin-extensions-vavoo_1.24_all.ipk
enigma2-plugin-extensions-youtube_h1-git1224-3393574-r0.0.ipk
enigma2-plugin-extensions-youtube_py3-git1224-3393574-r0.0.ipk
enigma2-plugin-extensions-levi45multicammanager_10.1-r26_all.deb
enigma2-plugin-extensions-vavoo_1.24_all.deb
12:06
Satellite-Forum.Com
levi45 Multicam Manager UPDATE 08-09-2024
enigma2-plugin-softcams-oscam-emu-levi45_11825-802_all.ipk
enigma2-channellist-ciefp-motor-abertis-arm_07-09-2024_all.ipk
enigma2-channellist-ciefp-motor-abertis-mips_07-09-2024_all.ipk
enigma2-plugin-softcams-oscam-emu-levi45_11825-802_all.deb
Satellite-Forum.Com
levi45 Addons Panel UPDATE 08-09-2024
enigma2-plugin-extensions-apod_1.1_all.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.11.2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.11.2_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.11.2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.11.2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.12_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.12_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.12_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.12_mips32el.ipk
enigma2-plugin-extensions-iptvarchive_2.0.85_all.ipk
enigma2-plugin-extensions-noipautologin_0.3-r0_all.ipk
enigma2-plugin-extensions-noipdyndns-modded_experimental-1.31_all.ipk
enigma2-plugin-extensions-xstreamity_4.58.20240907_all.ipk
enigma2-plugin-extensions-apod_1.1_all.deb
enigma2-plugin-extensions-iptvarchive_2.0.85_all.deb
enigma2-plugin-extensions-xstreamity_4.58_20240907_all.deb
Satellite-Forum.Com
11
06:25
Satellite-Forum.Com
levi45 Addons Panel UPDATE 10-09-2024
enigma2-plugin-softcams-oscam-emu-levi45_11827-802_all.ipk
enigma2-plugin-extensions-apod_1.2_all.ipk
enigma2-plugin-skins-xDreamy_3.0.0_all.ipk
enigma2-plugin-softcams-oscam-emu-levi45_11827-802_all.deb
enigma2-plugin-extensions-apod_1.2_all.deb
levi45 Multicam Manager UPDATE 10-09-2024
24
05:58
levi45 Addons Panel UPDATE 23-09-2024
Satellite-Forum.Com
enigma2-plugin-extensions-wireguard-vpn_11.2_all.ipk
enigma2-plugin-extensions-wireguard-vpn-aarch64_11.2_all.ipk
enigma2-plugin-extensions-wireguard-vpn-mips_11.2_all.ipk
enigma2-plugin-extensions-cerashlogviewer_1.4_all.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py2_cortexa9hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py3_3.11.2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py3_3.11.2_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py3_3.11.2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py3_3.11.2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py3_3.12_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py3_3.12_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py3_3.12_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.14.1_py3_3.12_mips32el.ipk
enigma2-plugin-skins-aglare-fhd_4.3_all.ipk
enigma2-plugin-skins-diana-fhd_3.3_all.ipk
enigma2-plugin-softcams-oscamicamnew_11836-ICAMEMU-Kitte888-V9Rev_all.ipk
enigma2-plugin-extensions-screengrabber_3.1_all.deb
enigma2-plugin-extensions-crashlogviewer_1.4_all.deb
enigma2-skin-hdsuisse.2k_3.8_all.deb
enigma2-skin-hdsuisse.fhd_merlin_10.4_all.deb
enigma2-skin-hdsuisse.one4all.fhd_10.4_all.deb
Satellite-Forum.Com
- 60 Replies
- 3425 Views
- 10 Replies
- 238 Views
- 4 Replies
- 96 Views
- 1461 Replies
- 49173 Views
- 206 Replies
- 41898 Views
Last post by Jack_Krauser777
