X Klass - Xtream Codes IPTV Player (new)
- afat45
- SW FEED HUNTER
- Been thanked: 27 times
25
13:13
V 1.11 - 25/08/2024 :face with monocle:
This plugin is a rework of my XStreamity plugin but with all new layout and new side menu accessible by the "Menu" button.
:beer1: https://paypal.me/kiddac :beer1: or :hot beverage: https://ko-fi.com/kiddac :hot beverage:
Feeds are sometimes a little behind. (note this is a brand new plugin - feeds will catchup)
openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies. (Xstreamity plugin in feeds will also load the dependencies)
Dreamboxes - python3
- enigma2-plugin-extensions-xklass_1.11_20240825_all.deb.rar
- (5.1 MiB) Downloaded 11 times
- enigma2-plugin-extensions-xklass_1.11.20240825_all.rar
- (5.34 MiB) Downloaded 12 times
- afat45
- SW FEED HUNTER
05:07
Re: X Klass - Xtream Codes IPTV Player (new)
V 1.12 - 25/08/2024
V 1.12 - 25/08/2024
- enigma2-plugin-extensions-xklass_1.12_20240825_all.deb.rar
- enigma2-plugin-extensions-xklass_1.12.20240825_all.rar
- (5.35 MiB) Downloaded 14 times
14:17
V 1.13 - 08/09/2024
V 1.13 - 08/09/2024
- enigma2-plugin-extensions-xklass_1.13.20240908_all.rar
- (5.35 MiB) Downloaded 9 times
15
04:41
V 1.14 - 14/09/2024
tnx KiddaC
V 1.14 - 14/09/2024
tnx KiddaC
- enigma2-plugin-extensions-xklass_1.14.20240915_all.rar
- (5.37 MiB) Downloaded 10 times
- Has thanked: 6 times
- Been thanked: 94 times
15
10:29
V 1.15 - 15/09/2024
V 1.15 - 15/09/2024
- enigma2-plugin-extensions-xklass_1.15_20240915_all.deb
- (5.11 MiB) Downloaded 7 times
- enigma2-plugin-extensions-xklass_1.15.20240915_all.ipk
- (5.37 MiB) Downloaded 7 times
Please use only "Like button", no need to write thanks
23
15:32
XKlass v1.16
updt_21-09-2024
Redirect fixes
Expired line crash fix
Greece, Italy, Portugal Language transaltion updates
updt_21-09-2024
Redirect fixes
- enigma2-plugin-extensions-xklass_1.16_20240921_all.deb
- (5.11 MiB) Downloaded 4 times
- enigma2-plugin-extensions-xklass_1.16.20240921_all.ipk
- (5.37 MiB) Downloaded 4 times
27
05:36
XKlass v1.17
I think I have fixed that tmdb variable crash
Also added in a few more amends for stripping out of some prefixes to help names work better with tmdb searching
- enigma2-plugin-extensions-xklass_1.17_20240926_all.deb
- (5.11 MiB) Not downloaded yet
- enigma2-plugin-extensions-xklass_1.17.20240926_all.ipk
- (5.37 MiB) Downloaded 5 times
- 14 Replies
- 912 Views
- 20 Replies
- 2949 Views
- 12 Replies
- 646 Views
- 223 Replies
- 64473 Views
Last post by Jack_Krauser777
- 31 Views
