New Update:15.04.2024
Fixed vulnerabilities:
-SFTP: Fixed PuTTY ECDSA NIST P-521 private key recovery vulnerability (CVE-2024-31497). If you use NIST P-521 keys to connect to SSH/SFTP servers, you should regenerate them and revoke the previous ones.
FileZilla Latest Version
Apr 2024
16
17:36
FileZilla Client is 3.67.0
- Been thanked: 293 times
Apr 2024
13:23
Re: FileZilla Latest Version
FileZilla Server v1.8.2 Released
Download FileZilla Server v1.8.2
https://filezilla-project.org/download. ... ype=server
New Update:26.04.2024
FileZilla Server now requires that the configuration directory is owned either by the operating system user account the server runs under, or a more privileged user (SYSTEM, Amdministrators, TrustedInstaller on Windows, root elsewhere)
MSW: Mount points are now case-insensitive so that restrictions on sub mounts cannot be bypassed by a change of character case..
Bugfixes and minor changes:
Fixed a potential deadlock during transfers..
FTP: Fixed potential crash if the session gets closed..
28
04:41
FileZilla Client v3.67.1-rc1 Released
Download FileZilla Client
https://filezilla-project.org/download. ... l=1&beta=1
New Update:27.06.2024
- Fixed an issue migrating old queue files if several older versions have been skipped..
- Updated to libfilezilla 0.48.0..
10
16:45
FileZilla Client v3.67.1 Released
New Update:10.07.2024
- MSW: Fixed an issue with confirmation dialogs for file deletion not being modal..
- Updated to libfilezilla 0.48.1..
https://filezilla-project.org/download.php?show_all=1
- Been thanked: 121 times
13:48
FileZilla Server v1.9.0-rc1 Released
New Update:08.08.2024
New features:
- Private keys used for TLS can now be stored on a PKCS#11-compatible token device; the UI has been updated accordingly.
- UI: added button to retrieve the current FileZilla Server's public IP address, useful to configure the PASV mode.
- UI: added an FTP connection test, that can be reached directly from the Server menu item or executed at the end of the FTP Network Configuration Wizard.
- Made default values more secure, among which: require TLS on new FTP listeners, require a password for new users and warn if the administration password doesn't meet more stringent security requirements.
- Fixed bug causing the most recent log file, rather than the oldest, to be deleted upon rotation, when using dates as suffixes.
- MSW: fixed regression causing socket listener conflicts due to recent libfilezilla changes.
- Added WebUI: an HTTP server providing a REST API and a web app for seamless web access to stored files. WebUI is not included in the default build and must be enabled with the --enable-webui parameter during compilation. This feature is experimental; feedback and bug reports are welcome.
- UI: the certificate fingerprint verification dialog is now sized to display the full fingerprint at once.
- UI: fixed bug causing the focus to be lost during user editing.
- UI: fixed bug causing the tray icon to display unexpectedly in certain cases.
- UI: improved error handling in case of server disconnection.
- UI: improved handling of Settings window size on ultra wide screens.
- FTP: the MKD command now returns an error if the directory already exists.
- FTP: Improved login timeout handling to exclude internal server processing time.
- Fixed heap corruption in the Administrator Interface.
- Fixed regression in the path handling routines.
New features:
05
15:47
FileZilla Server v1.9.0 Released
New Update:05.09.2024
- MSW: Warn if installing the server outside of Program Files due to custom directories having too lax permissions..
- Fixed a race condition resulting in stalled connections..
- *nix: Fixed a potential crash if SIGINT is sent to the server while it is shutting down..
- Fixes to the update check mechanism..
- Fixed a regression in the converter for old 0.9.x configurations dealing with placeholders in native paths.
10
05:40
FileZilla Server v1.9.1 Released
New Update:09.09.2024
- Fixed a regression introduced in 1.9.0, the "public IP or hostname" field on the passive mode page was not restored when opening the settings dialog
Oct 2024
01
13:13
FileZilla Server v1.9.2 Released
New Update:30.09.2024
- Fixed an issue with the update mechanism..
Oct 2024
05:32
FileZilla Server v1.9.3 Released
New Update:17.10.2024
- Fixed a regression causing the automatic renewal of the Let's Encrypt® certificates to not work properly..
- UI: fixed regression causing the Administration Interface port of the last successful connection to not be properly restored..
- UI: fixed a bug where the TLS key appeared to be lost in the interface if certificate generation failed, even though the key was still retained on the server..
- 30 Replies
- 3357 Views
Last post by kalpikos
- 1262 Views
- 19 Replies
- 1860 Views
- 4 Replies
- 741 Views
- 124 Views
