[E² Plugin] Wireguard-VPN
Been thanked: 157 times
Re: [E² Plugin] Wireguard-VPN
#31
Update Online WireGuard VPN V.11.9
* Fixed channel resume (streaming) if another server is started in Personal files.
* Added skin selection (Thanks for the Mmark skin).
* Updated the French translation (thanks gruick1).
Python 3.9 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .9_all.ipk
Python 3.11 (ARM - End of support): https://github.com/m4dhouse/Wi…ireguard ... .9_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .9_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wi…-vpn-aar ... .9_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wi…ard-vpn- ... .9_all.ipk
#32
Update Online WireGuard VPN V.12.0
09.11.2024
* If the backup file has been created it asks with a PopUp if you want to import it.
* Added skin Grey.
* Updated the German translation (thanks Tommy007)
* Updated the Greek translation (thanks giorbak)
* Update .po and .pot files.
thanks madhouse
Python 3.9 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .0_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .0_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wi…-vpn-aar ... .0_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wi…ard-vpn- ... .0_all.ipk
#33
Update Online WireGuard VPN V.12.1
* Fix UnboundLocalError: local variable 'backup_dir' referenced before assignment (thanks gigafox72)
thanks madhouse
Python 3.9 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .1_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .1_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wi…-vpn-aar ... .1_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wi…ard-vpn- ... .1_all.ipk
#34
Update Online WireGuard VPN V.12.2
* Fixed installation of dependencies.
* Added sounds option.
* Added page numbering.
* Updated the German translation (thanks Tommy007 ).
* Updated the Greek translation (thanks giorbak ).
https://github.com/m4dhouse/Wireguard-Vpn
#35
Update Online WireGuard VPN V.12.3
* Added more selectable sounds.
* Fixed the search for online updates if you are connected via VPN.
* Fixed key mapping.
* Update po and pot files.
Python 3.9 (ARM): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.11 (ARM - End of support): https://github.com/m4dhouse/Wireguard-V ... .9_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
#36
Update Online WireGuard VPN V.12.4
* Fixed the configuration for personal files, in some cases it did not show the Disconnect button.
* Fixed backup creation and restore for Mipsel boxes (Thanks foreverMiky64).
* Added Russian translation (Thanks airforce).
* Updated the German translation (thanks Tommy007).
* Updated the Greek translation (thanks giorbak).
#37
Update Online WireGuard VPN V.12.5
* Added option to use sound in enigma2 (experimental) after exiting the plugin.
* Added another host to check IP, country and ping.
* Now using your personal files make 2 attempts to establish the tunnel.
* Small graphic changes, change of sound when opening the plugin.
* Added Russian translation (Thanks airforce ).
Python 3.9 (ARM): https://github.com/m4dhouse/Wireguard-V ... .4_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
