The LATEST OSCAM-EMU FOR VARIOUS PLATFORMS
Been thanked: 165 times
Re: The LATEST OSCAM-EMU FOR VARIOUS PLATFORMS
#61
Oscam für DM9XXX / VU+ 4k / Gigablue 4K / SF8008 mit u. arm / mips / aach64 Support icam u. ibdvbcsa u. integriert ohne Emu
IPK nur für OpenATV Image: arm / mips / aach64
enigma2-plugin-softcams-oscam-icam-openatv_r11845_all.ipk
enigma2-plugin-softcams-oscam-icam-openatv-ipv6_r11845_all.ipk
IPK nur für VTI Image: arm / mips
enigma2-plugin-softcams-oscam-icam-vti_r11845_all.ipk
enigma2-plugin-softcams-oscam-icam-vti-ipv6_r11845_all.ipk
enigma2-plugin-softcams-oscam-icam-vti_r11845_all.zip
(2.45 MiB) Downloaded 15 times
enigma2-plugin-softcams-oscam-icam-openatv_r11845_all.zip
(4.19 MiB) Downloaded 17 times
enigma2-plugin-softcams-oscam-icam-ipv6-vti_r11845_all.zip
(2.46 MiB) Downloaded 16 times
enigma2-plugin-softcams-oscam-icam-ipv6-openatv_r11845_all.zip
(4.2 MiB) Downloaded 14 times
#62
thx samur
OSCam-11845-802
mipsel & aarch64
OSCam-11845-802 (mipsel libusb).zip
(685.91 KiB) Downloaded 16 times
OSCam-11845-802 (mipsel libusb pcsc).zip
(687.9 KiB) Downloaded 13 times
OSCam-11845-802 (mipsel libusb aio).zip
(735.58 KiB) Downloaded 15 times
OSCam-11845-802 (aarch64 libusb).zip
(753.35 KiB) Downloaded 16 times
OSCam-11845-802 (aarch64 libusb pcsc).zip
(755.03 KiB) Downloaded 16 times
#63
Oscam 11845-802 emu-icam-ipv6 ARM _Open SSL 3.2.1/3.3.0/3.3.1
Oscam 11845-802 emu-icam-ipv6 MIPSEL_Open SSL 3.2.1/3.3.0/3.3.1
Oscam 11845-802 emu-icam-ipv6 AARCH64_Open SSL 3.2.1/3.3.0/3.3.1
* New webif style
* Added CCcam.cfg reading to OSCam(CCcam.cfg path:etc/tuxbox/config.-Attributes 755)
Note:This option is active by default.
To enabled or disabled this option see attached screenshots.
Pay attention:
Do not activate the same cline on CCcam.cfg and oscam.server together, you risk being banned from the server!
oscam-git11845-802@44d9b86c-mips32el_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-signed.tar.gz
(846.25 KiB) Downloaded 15 times
oscam-git11845-802@44d9b86c-armv7_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-neon-signed.tar.gz
(755.18 KiB) Downloaded 14 times
oscam-git11845-802@44d9b86c-aarch64_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-signed.tar.gz
(776.6 KiB) Downloaded 13 times
#64
Oscam 11846-802 emu-icam-ipv6 ARM _Open SSL 3.2.1/3.3.0/3.3.1
Oscam 11846-802 emu-icam-ipv6 MIPSEL_Open SSL 3.2.1/3.3.0/3.3.1
Oscam 11846-802 emu-icam-ipv6 AARCH64_Open SSL 3.2.1/3.3.0/3.3.1
oscam-git11846-802@ae6e55a9-mips32el_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-signed.tar.gz
(846.31 KiB) Downloaded 11 times
oscam-git11846-802@ae6e55a9-armv7_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-neon-signed.tar.gz
(755.18 KiB) Downloaded 11 times
oscam-git11846-802@ae6e55a9-aarch64_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-signed.tar.gz
(776.63 KiB) Downloaded 14 times
#65
Oscam 11847-802 emu-icam-ipv6 ARM _Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
Oscam 11847-802 emu-icam-ipv6 MIPSEL_Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
Oscam 11847-802 emu-icam-ipv6 AARCH64_Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
oscam-git11847-802@d04b935a-mips32el_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-signed.tar.gz.zip
(845.79 KiB) Downloaded 10 times
oscam-git11847-802@d04b935a-armv7_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-neon-signed.tar.gz.zip
(754.59 KiB) Downloaded 11 times
oscam-git11847-802@d04b935a-aarch64_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-signed.tar.gz.zip
(776.03 KiB) Downloaded 11 times
#66
Before you use this ipk, pay attention to the file name of the ipk, because vti only with VTI image and openatv only with OpenATV image!!!!
Oscam for DM9XXX / VU+ 4k / Gigablue 4K / SF8008 with u. arm / mips / aach64 support icam and ibdvbcsa and integrated without Emu
IPK only for OpenATV image: arm / mips / aach64
enigma2-plugin-softcams-oscam-icam-openatv_r11847_all.ipk
enigma2-plugin-softcams-oscam-icam-openatv-ipv6_r11847_all.ipk
IPK only for VTI image: arm / mips
enigma2-plugin-softcams-oscam-icam-vti_r11847_all.ipk
enigma2-plugin-softcams-oscam-icam-vti-ipv6_r11847_all.ipk
enigma2-plugin-softcams-oscam-icam-vti_r11847_all.zip
(2.45 MiB) Downloaded 8 times
enigma2-plugin-softcams-oscam-icam-openatv_r11847_all.zip
(4.19 MiB) Downloaded 8 times
enigma2-plugin-softcams-oscam-icam-ipv6-vti_r11847_all.zip
(2.46 MiB) Downloaded 8 times
enigma2-plugin-softcams-oscam-icam-ipv6-openatv_r11847_all.zip
(4.2 MiB) Downloaded 8 times
#67
Oscam 11848-802 emu-icam-ipv6 ARM _Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
https://fastupload.io/cbaeb5a8e3eea0a4
Oscam 11848-802 emu-icam-ipv6 MIPSEL_Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
https://fastupload.io/ea19d59d95942424
Oscam 11848-802 emu-icam-ipv6 AARCH64_Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
https://fastupload.io/5a20cfe00c0d5224
signing: build warning when using elliptic curve signature algorithms with OpenSSL versions before 1.0.0
* pipeline: use rsa signature algorithm for ancient toolchain
#68
Oscam 11849-802 emu-icam-ipv6 ARM _Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
https://fastupload.io/85b687914a874def
Oscam 11849-802 emu-icam-ipv6 MIPSEL_Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
https://fastupload.io/e5799ea10ff36ed5
Oscam 11849-802 emu-icam-ipv6 AARCH64_Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
https://fastupload.io/e822e6e655157d34
* Remove tivusat hardware global emm fix as it is not required anymore.
#69
oscam-2.24.11-11849 with icam Commit
armv7
MIPS-OE2.0
raspberry Pi 3 B + , Pi 4 B aarch64
oscam-2.24.11-11849@f3d8575c-aarch64-rpi3-linux-gnu-ssl-libusb-libdvbcsa
https://fastupload.io/787974b91f9ce3ff
oscam-2.24.11-11849@f3d8575c-armv7-vuplus4k-linux-gnueabihf-ssl-libusb-libdvbcsa
https://fastupload.io/d4f8c2da2988ac3b
oscam-2.24.11-11849@f3d8575c-mipsel-unknown-linux-gnu-ssl-libusb-libdvbcsa
https://fastupload.io/549001b92e62695e
#70
Oscam 11851-803 emu-icam-ipv6 ARM _Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
https://fastupload.io/df4eb4d0630beca8
Oscam 11851-803 emu-icam-ipv6 MIPSEL_Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
https://fastupload.io/48962d7703598451
Oscam 11851-803 emu-icam-ipv6 AARCH64_Open SSL 3.2.1/3.3.0/3.3.1/3.3.2
https://fastupload.io/50c585dc06bfcf8b
