X-Streamity - Xtream Codes IPTV Player (new thread)
- Been thanked: 203 times
Re: X-Streamity - Xtream Codes IPTV Player (new thread)
XStreamity v4.61
26.09.2024
Right... I think I have fixed that tmdb variable crash
Also added in a few more amends for stripping out of some prefixes to help names work better with tmdb searching
26.09.2024
- enigma2-plugin-extensions-xstreamity_4.61_20240926_all.deb
- (3.92 MiB) Downloaded 31 times
- enigma2-plugin-extensions-xstreamity_4.61.20240926_all.ipk
- (4.29 MiB) Downloaded 30 times
XStreamity v4.62
Fixed catchup margins
Updated spanish translations
Removed xmltv epg timeout
Minor tweaks
Minor tweaks
- enigma2-plugin-extensions-xstreamity_4.62.20241026_all.ipk
- (4.29 MiB) Downloaded 27 times
XStreamity v4.63
28.10.2024
Catchup amends again. Slightly different approach
Fixed recording stripping out accented characters
Reverted some code in the downloader, so should now work like it used to work.
28.10.2024
- enigma2-plugin-extensions-xstreamity_4.63_20241028_all.deb
- (3.92 MiB) Downloaded 28 times
- enigma2-plugin-extensions-xstreamity_4.63.20241028_all.ipk
- (4.29 MiB) Downloaded 28 times
X-Streamity - Official
Release_ v. 4.64 _12/11/2024
Note: openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies.
thanks Kiddac
enigma2-plugin-extensions-xstreamity_4.64.20241112_all.ipk enigma2-plugin-extensions-xstreamity_4.64_20241112_all.deb
thanks Kiddac
XStreamity V4.65
- update
enigma2-plugin-extensions-xstreamity_4.65.20241122_all.ipk enigma2-plugin-extensions-xstreamity_4.65_20241122_all.deb
- update
- Has thanked: 78 times
- Been thanked: 27 times
xStreamity - Official Release.
V 4.66 - 27/11/2024
V 4.66 - 27/11/2024
X-Streamity - Official Release.
V 4.66 - 27/11/2024
V 4.66 - 27/11/2024
- enigma2-plugin-extensions-xstreamity_4.66_20241127_all.deb
- (3.92 MiB) Downloaded 21 times
- enigma2-plugin-extensions-xstreamity_4.66.20241127_all.ipk
- (4.29 MiB) Downloaded 20 times
XStreamity v4.67
thanks kiddac
Downloader updates.
Fixed the wget message issue
I now no longer delete completed downloads
Invalid URLs will say "Error"
Downloads do not stop when re-entering the downloader.
thanks kiddac
Downloader updates.
- enigma2-plugin-extensions-xstreamity_4.67_20241201_all.deb
- (3.92 MiB) Downloaded 22 times
- enigma2-plugin-extensions-xstreamity_4.67.20241201_all.ipk
V 4.67 - 02/12/2024
Fixed those live recording crashes in the last release
V 4.67 - 02/12/2024
- enigma2-plugin-extensions-xstreamity_4.67_20241202_all.deb
- enigma2-plugin-extensions-xstreamity_4.67.20241202_all.ipk
- (4.29 MiB) Downloaded 23 times
X-Streamity - Official Release V 4.68 - 14/12/2024
removed wget check
removed user-agent 'Connection': 'keep-alive',
amended vod downloader code.
You might need to delete your original downloads file if some are stuck in the wrong state.
/etc/enigma2/xstreamity/downloads2.json
removed wget check
- enigma2-plugin-extensions-xstreamity_4.68_20241214_all.deb
- (3.92 MiB) Downloaded 15 times
- enigma2-plugin-extensions-xstreamity_4.68.20241214_all.ipk
- (4.29 MiB) Downloaded 14 times
- 12 Replies
- 1154 Views
- 22 Replies
- 832 Views
- 14 Replies
- 1208 Views
- 229 Replies
- 82272 Views
Last post by SATWORLD
- 7 Replies
- 171 Views
