X Klass - Xtream Codes IPTV Player (new)
Been thanked: 206 times
Re: X Klass - Xtream Codes IPTV Player (new)
#21
V 1.30 - 22/12/2024
This plugin is a rework of my XStreamity plugin but with all new layout and new side menu accessible by the "Menu" button.
This plugin only plays xtream code playlists and does not play other playlists or m3u playlists.
enigma2-plugin-extensions-xklass_1.30_20241223_all.deb.rar
(5.12 MiB) Downloaded 30 times
enigma2-plugin-extensions-xklass_1.30.20241223_all.rar
(5.37 MiB) Downloaded 31 times
#22
V 1.31 - 23/12/2024
enigma2-plugin-extensions-xklass_1.31_20241223_all.deb.rar
(5.12 MiB) Downloaded 38 times
enigma2-plugin-extensions-xklass_1.31.20241223_all.rar
(5.37 MiB) Downloaded 32 times
#23
V 1.32- 10/01/2025
Replace brackets ( ) [ ] in filenames to prevent a certain software crash that doesn't like them.
enigma2-plugin-extensions-xklass_1.32_20250110_all.deb
(5.12 MiB) Downloaded 36 times
enigma2-plugin-extensions-xklass_1.32.20250110_all.ipk
(5.37 MiB) Downloaded 37 times
#24
V 1.33 - 01/02/2025 :face with monocle:
github.com
kiddac - Overview
kiddac has 17 repositories available. Follow their code on GitHub.
github.com github.com
Feeds are sometimes a little behind.
openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies. (Xstreamity plugin in feeds will also load the dependencies)
Dreamboxes - python3
enigma2-plugin-extensions-xklass_1.33_20250201_all.deb
(5.11 MiB) Downloaded 4 times
enigma2-plugin-extensions-xklass_1.33.20250201_all.ipk
(5.38 MiB) Downloaded 15 times
#25
V 1.34 - 04/02/2025 :face with monocle:
enigma2-plugin-extensions-xklass_1.34_20250204_all.deb.rar
(5.12 MiB) Downloaded 1 time
enigma2-plugin-extensions-xklass_1.34.20250204_all.rar
(5.38 MiB) Downloaded 3 times
