V 1.30 - 22/12/2024
This plugin is a rework of my XStreamity plugin but with all new layout and new side menu accessible by the "Menu" button.
This plugin only plays xtream code playlists and does not play other playlists or m3u playlists.
X Klass - Xtream Codes IPTV Player (new)
- Been thanked: 206 times
Re: X Klass - Xtream Codes IPTV Player (new)
- enigma2-plugin-extensions-xklass_1.30_20241223_all.deb.rar
- (5.12 MiB) Downloaded 30 times
- enigma2-plugin-extensions-xklass_1.30.20241223_all.rar
- (5.37 MiB) Downloaded 31 times
V 1.31 - 23/12/2024
V 1.31 - 23/12/2024
- enigma2-plugin-extensions-xklass_1.31_20241223_all.deb.rar
- (5.12 MiB) Downloaded 38 times
- enigma2-plugin-extensions-xklass_1.31.20241223_all.rar
- (5.37 MiB) Downloaded 32 times
V 1.32- 10/01/2025
Replace brackets ( ) [ ] in filenames to prevent a certain software crash that doesn't like them.
V 1.32- 10/01/2025
- enigma2-plugin-extensions-xklass_1.32_20250110_all.deb
- (5.12 MiB) Downloaded 36 times
- enigma2-plugin-extensions-xklass_1.32.20250110_all.ipk
- (5.37 MiB) Downloaded 37 times
V 1.33 - 01/02/2025 :face with monocle:
github.com
kiddac - Overview
kiddac has 17 repositories available. Follow their code on GitHub.
github.com github.com
Feeds are sometimes a little behind.
openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies. (Xstreamity plugin in feeds will also load the dependencies)
Dreamboxes - python3
github.com
kiddac - Overview
- enigma2-plugin-extensions-xklass_1.33_20250201_all.deb
- (5.11 MiB) Downloaded 4 times
- enigma2-plugin-extensions-xklass_1.33.20250201_all.ipk
- (5.38 MiB) Downloaded 15 times
V 1.34 - 04/02/2025 :face with monocle:
- enigma2-plugin-extensions-xklass_1.34_20250204_all.deb.rar
- (5.12 MiB) Downloaded 2 times
- enigma2-plugin-extensions-xklass_1.34.20250204_all.rar
- (5.38 MiB) Downloaded 4 times
- 14 Replies
- 1212 Views
- 37 Replies
- 4323 Views
- 12 Replies
- 1170 Views
- 229 Replies
- 82820 Views
Last post by SATWORLD
- 9 Replies
- 186 Views
