-Fixed stream request format for some IPTV providers
-Changed the pause algorithm for standard Enigma2 stream "players" (1:, 4097:, 8739:)
Thx @ Pepsik
[Plugin] IPTVArchive
- Has thanked: 68 times
- Been thanked: 23 times
Apr 2024
29
08:56
Update IPTV Archive Ver 2.0.78
- enigma2-plugin-extensions-iptvarchive_2.0.78_all.rar
- (2.03 MiB) Downloaded 78 times
- Been thanked: 279 times
May 2024
14
06:50
Re: [Plugin] IPTVArchive
UPDATE 2.0.80
The ability to select the source of “depth” of archived records has been added to the plugin settings. The following options are available:
a) 'from the playlist' - in this case, the 'depth' values of archived recordings will be taken from the values of the corresponding tags of the playlist used. If the playlist does not have tags responsible for the “depth” of the archives, then the default values are specified in the plugin code for the IPTV provider you used.
b) 'by default' - the 'depth' of days for archived broadcasts will be obtained from the default values set for your IPTV provider in the plugin code
c) 'user defined' - the 'depth' of days for archived broadcasts will correspond to that specified by the user. The specified value will apply to all IPTV providers. With this setting, you will receive a list of archived broadcasts to the depth you specify, but whether there will be broadcasts when requested from the provider’s servers is determined only experimentally.
2.0.79
1) The logic for working with alternative APIs has been modernized for greater cross-compatibility between different IPTV providers
2) The logic for searching archived broadcasts by channel name has been modified if they are not found in the specified APIs
3) German localization fixed
2.0.79
- enigma2-plugin-extensions-iptvarchive_2.0.80_all.rar
- (2.05 MiB) Downloaded 63 times
![Image](https://i.imgur.com/bwC5czT.gif)
May 2024
06:09
UPDATE 2.0.81
1) Fixed a crash that occasionally occurred when FF/RW or exiting the view using the "exit" button
2) Added caching of API requests/responses to reduce the number of unnecessary calls
- enigma2-plugin-extensions-iptvarchive_2.0.81_all.rar
- (2.06 MiB) Downloaded 80 times
04
12:40
IPTV Archive Ver 2.0.82
1) Fixed a bug with the inability to select the key-file from the root directory
2) Minor code optimization
- enigma2-plugin-extensions-iptvarchive_2.0.82_all.rar
- (1.03 MiB) Downloaded 58 times
- 1 Views
- 1091 Views
- 22 Replies
- 3818 Views
- 1176 Views
- 1647 Views
