[E² Plugin] MultiStalker-Pro
- Been thanked: 293 times
enigma2-plugin-extensions-multi-stalkerpro_1.1+git47
Fixed bug on watchlist.
enigma2-plugin-extensions-multi-stalkerpro_1.1+git47+d764d630+d764d63d92-r0_cortexa15hf-neon-v...ipk (2.56MB)
https://www.sendspace.com/file/r4vuwy
Re: [E² Plugin] MultiStalker-Pro
PY3.12 ARM for VIX/OBH
- built-in missing gui components
this ipk is only for this two images.
enigma2-plugin-extensions-multi-stalkerpro_1.1+git142+3c917ef0+3c917ef553-r0_cortexa15hf-neon-...ipk (2.88MB)
https://www.sendspace.com/file/lkbtc8
enigma2-plugin-extensions-multi-stalkerpro_1.1+git144+4ef83e7-r0_mips32el
OPENPLi develop image only
python3-rarfile_4.1-r0_mips32el.ipk (31.49KB)
https://www.sendspace.com/file/epmvol
python3-levenshtein_0.12.0-r0_mips32el.ipk (24.14KB)
https://www.sendspace.com/file/nopa9x
python3-fuzzywuzzy_0.18.0-r0_mips32el.ipk (9.03KB)
https://www.sendspace.com/file/swl2fo
enigma2-plugin-extensions-multi-stalkerpro_1.1+git144+4ef83e7-r0_mips32el.ipk (1.92MB)
https://www.sendspace.com/file/h7mypc
OPENPLI DEVELOP
- enigma2-plugin-extensions-multi-stalkerpro_1.1+git165+24295f8-r0_armv7ahf-neon.ipk
- (1.98 MiB) Downloaded 96 times
- python3-rarfile_4.1-r0_armv7ahf-neon.ipk
- (31.49 KiB) Downloaded 115 times
- python3-levenshtein_0.12.0-r0_armv7ahf-neon.ipk
- (20.7 KiB) Downloaded 95 times
- python3-levenshtein_0.12.0-r0_armv7ahf-neon-1.ipk
- (20.7 KiB) Downloaded 109 times
- python3-fuzzywuzzy_0.18.0-r0_armv7ahf-neon.ipk
- (9.03 KiB) Downloaded 109 times
VIX/OBH
AARCH64
AARCH64
- enigma2-plugin-extensions-multi-stalkerpro_1.1+git165+24295f80+24295f8904-r0_aarch64.ipk
- (2.73 MiB) Downloaded 104 times
- python3-rarfile_4.1-r0_aarch64.ipk
- (58.48 KiB) Downloaded 101 times
A beta test for arm (ATV/PURE/EGAMI)
- Add support for xtream subscriptions
- Add a web interface to add/remove or edit a portal and also you can add your api keys from the web interface
The structure of MultistalkerPro.json had been changed so you need to add again you protals trough the web interface and its better to empty the MultistalkerPro.json file
you can access the web interface with the same ip of webinterface following with /multi-stalkerpro/portals
for example my box ip is: 192.168.1.88 so the web interface url is
http://192.168.1.88/multi-stalkerpro/portals
- enigma2-plugin-extensions-multi-stalkerpro_1.1+git92+9846d680+9846d68c94-r0_cortexa15hf-neon-v...ipk
- (2.76 MiB) Downloaded 146 times
V1.2
- Fix EPG
- Prevent memory leaks caused by some channels picons by limiting the resolution to 1280x720
- Enable series special season if available
- Fix navigations in portals selection with pure2 image
- Update translation files
- Major improvements and bug fixes
Only for arm devices and for (atv/pure/egami) Python3.12.2/3.12.3.
- Fix EPG
opkg install --force-depends /tmp/*.ipk
- enigma2-plugin-extensions-multi-stalkerpro_1.1+git94+247e9ab0+247e9ab8e1-r0_cortexa15hf-neon-v...ipk
- (2.79 MiB) Downloaded 114 times
