[E² Plugin] TS-E2iplayer
Been thanked: 279 times
May 2024 16 05:10
Re: [E² Plugin] TS-E2iplayer
Post by sugar
15/05/2024
vsTream:
- illimitestreaming - upgrade to new site
- dood - resolve a redirect
- filmsetvideos - New site
- voe - new format support
- year 2024
- hoster moacloud and duxcloud
- adkami_com - better search results
- wilifilm - link retrieval update
- livetv - winter time + link processing
- sites - address update
- Change the Content-type to respect FlareSolverr expectation
- pastebin - correction: series by broadcaster
- channelstream - Winter time + link
- juststream - in progress to find links
- Cleaning up dead sources.
- neymartv - links back
- sports links
update version
Remove Watanflix
update link Shahid4u
fix TaxiElCima
update Esheeq
update link CoolCima
update link Cima4u
Add New Host basketballvideo
add parser nflinsider.net
update Matrix ver: 6.4.0k
Update Link Brstej
Stop Support Python 2
Thanks MOHAMED OS
To install run the following command in telnet
wget --no-check-certificate "https://gitlab.com/MOHAMED_OS/e2iplayer/-/raw/main/install-e2iplayer.sh?inline=false" -qO - | /bin/sh
e2iplayer.rar
(17.04 MiB) Downloaded 96 times
May 2024 20 06:25
Post by sugar
19/05/2024
update version
add option to show add to IPAudio
minor cleanup
try fix Altadefinizione
use fstring
try fix Cima4u
try fix BasketballVideo
Matrix: fix f-string: unmatched
Matrix: try fix ArabSeed
update link ArabSeed
Thanks MOHAMED OS
e2iplayer.zip
(17.4 MiB) Downloaded 90 times
May 2024 23 04:49
Post by sugar
[E² Plugin] TS-E2iplayer22/05/2024
update version
update link faselhd
Matrix: Up ver 6.4.0n
vStream: use f-string
Matrix: fix error No module
try fix FaselHD
Thanks MOHAMED OS
userbouquet.iptv.xiaomi.rar
(6.95 KiB) Downloaded 96 times
Has thanked: 71 times
Been thanked: 23 times
Jun 2024 01 12:48
Post by ocean777
31/05/2024
Update link Extra3sk
Update Cima4u
Update link Brstej
Update BahyFilm
Update ArabSeed
Update ArabLionz
Minor cleanup
Fix parser STAYONLINE
try fix GamatoMovies
Matrix: update version 6.4.0r
Matrix: Update sites.json
Shahid4u update link
Replace eAVSwitch with iAVSwitch, all image use iAVSwitch dont use eAVSwitch
Thanks MOHAMED OS
31/05/2024
e2iplayer.rar
(17.02 MiB) Downloaded 70 times
Jun 2024 07 05:48
Post by sugar
06/06/2024
Update version
Add show info in list
Add parser:
- supervideo.cc
- mixdrop.ms
Update Show Info:
- Akwam
- Akoam
- Aflaam
Matrix: Update Version 6.4.0s
Update Akwam
Update link WeCima
Fix AnimeLek
Update link Shahid4u
Add parser:
- tapeadvertisement.com
- brucevotewithin.com
- swhoi.com
Thanks MOHAMED OS
e2iplayer.zip
(17.35 MiB) Downloaded 47 times
Jun 2024 10 04:38
Post by sugar
09/06/2024
update version
minor cleanup
use import_module
matrix : clean
matrix: Add Freebox
Matrix: Update version 6.4.0t
update Brstej
Thanks MOHAMED OS
wget -qO- --no-check-certificate https://gitlab.com/MOHAMED_OS/e2iplayer/-/raw/main/install-e2iplayer.sh?inline=false -qO - | bash
e2iplayer.rar
(17.04 MiB) Downloaded 46 times
Jun 2024 13 04:42
Post by sugar
12/06/2024
update version
minor cleanup
fix cima4u
update script
Thanks MOHAMED OS
** To install run the following command in telnet **
or
curl -LJso- https://gitlab.com/MOHAMED_OS/e2iplayer/-/raw/main/install-e2iplayer.sh?inline=false | bash
e2iplayer.zip
(17.38 MiB) Downloaded 45 times
Jun 2024 17 05:37
Post by sugar
16/06/2024
vStream:
- 1seriestreaming - refresher course
- Doc4U: Source for docs and TV shows
vStream: neymartv - remise en forme
Add parser swdyu.com
vsTream:
- wiflix Site upgrade
- Ergonomics
Update ArabSeed
Update Cima4u
Add New CinemaBest
Update Script Install
Minor cleanup
Update Mtrix: 6.4.0ufix
vsTream: Address update
Update Link:
- TvFun
- MovizTime
Thanks MOHAMED OS
OR
e2iplayer.rar
(21.46 MiB) Downloaded 31 times
Jun 2024 22 06:43
Post by sugar
21/06/2024
Update version
try fix Seezsu
Update Host
Update Cima4u
fix show title
Update Link:
- Anime4up
- MovizTime
- Brstej
vStream: Update wilifilm
vStream:
- wiflix - Propose VOSTFR links
- neymartv - find more channels
Thanks MOHAMED OS
OR
e2iplayer.zip
(21.8 MiB) Downloaded 12 times
Jun 2024 28 04:50
Post by sugar
27/06/2024
Update Link Cinemana
try fix parserDOOD
try fix dukVersion for OpenPli
try fix AnimeBlkom
Matrix: update Version 6.4.0w
vStream:
- More sports links
minor cleanup
vStream:
- LiveTV - New address
- neymartv - More links
- livetv - link resolution
- DNSPython - timeout management
Thanks MOHAMED OS
OR
e2iplayer.zip
(21.8 MiB) Downloaded 6 times
