Xtream Codes IPTV Player (new)
- Has thanked: 3 times
- Been thanked: 77 times
05:14
X Klass - Official Release
V 1.00 - 07/07/2024
This plugin is a rework of XStreamity plugin but with all new layout and new side menu accessible by the "Menu" button.
I work non stop on my plugins. It's hard work. If you like my work and you want me to continue, you can always show your appreciation by buying me a beer
Github Repository - Git is updated as soon as a release is bug free and stable
IPTV is perfectly legal - IPTV providers/playlists that contain unscrambled encrpyted channels are illegal.
User is responsible for any downloaded playlist content.
Feeds are sometimes a little behind. (note this is a brand new plugin - feeds will catchup)
openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies.
python3
V 1.00 - 07/07/2024
python3
- enigma2-plugin-extensions-xklass_1.00_20240707_all.deb
- (5.1 MiB) Downloaded 21 times
- enigma2-plugin-extensions-xklass_1.00.20240707_all.ipk
- (5.34 MiB) Downloaded 21 times
05:16
XKlass v1.01
Fixed python 2.7 crash
- enigma2-plugin-extensions-xklass_1.01_20240707_all.deb
- enigma2-plugin-extensions-xklass_1.01.20240707_all.ipk
- (5.34 MiB) Downloaded 16 times
05:18
XKlass v1.02
fixed a multiprocessing crash on some barebones images
- (5.1 MiB) Downloaded 17 times
- (5.34 MiB) Downloaded 17 times
- Been thanked: 25 times
10
06:18
Re: Xtream Codes IPTV Player (new)
v.1.03
Tnx.KiddaC
Tnx.KiddaC
- enigma2-plugin-extensions-xklass_1.03.20240709_all.rar
- (5.34 MiB) Downloaded 22 times
08:00
XKlass - Official Release.
V 1.04 - 15/07/2024
Fixed the crash if default playlist is not active or not responding - playlists screen should now show instead.
Blue button functionality returns on the start menu - to delete the working json data files - Use when things are going weird.
Code tweak to how and when custom sids (satellite refs) for epgs are picked up.
Removed blank epg importer source file. Not needed. It gets built if required.
Translation updates for spain, china and germany.
New intro video selection option - for those users putting alternative videos in the video folder.
Slight tweak to the logic of determining if a playlist has been switched or not.
V 1.04 - 15/07/2024
- enigma2-plugin-extensions-xklass_1.04_20240715_all.deb
- (5.1 MiB) Downloaded 16 times
- enigma2-plugin-extensions-xklass_1.04.20240715_all.ipk
- (5.34 MiB) Downloaded 13 times
08:01
V 1.05 - 16/07/2024
Fixed the start menu loop if one of the urls was failing. Now correctly looks for 1 valid url, not all valid urls
Added asterisks into channel name clean ups
Added Chinese language option for TMDB data
Slight update to Italian translation
V 1.05 - 16/07/2024
- enigma2-plugin-extensions-xklass_1.05_20240716_all.deb
- enigma2-plugin-extensions-xklass_1.05.20240716_all.ipk
19
05:14
V1.06 - experimental release
Just added a couple of default sort options for VOD. (not live or series)
I got this terrible wrong last time I did this so lets see if this is any better.
- enigma2-plugin-extensions-xklass_1.06_20240718_all.deb
- enigma2-plugin-extensions-xklass_1.06.20240718_all.ipk
- (5.34 MiB) Downloaded 18 times
23
16:37
XKlass v1.07
Update German Translations
Relaxed the rules around json content. It was a little strict.
- enigma2-plugin-extensions-xklass_1.07_20240723_all.deb
- enigma2-plugin-extensions-xklass_1.07.20240723_all.ipk
24
05:27
XKlass v1.08
Series episode duration should now show correctly if available, whether TMDB turned on or of
- enigma2-plugin-extensions-xklass_1.08_20240723_all.deb
- (5.1 MiB) Downloaded 11 times
- enigma2-plugin-extensions-xklass_1.08.20240723_all.ipk
05:15
V 1.10 - 26/07/2024
Fix for older images missing twisted web client BrowserLikePolicyForHTTPS
V 1.10 - 26/07/2024
- enigma2-plugin-extensions-xklass_1.10_20240726_all.deb
- enigma2-plugin-extensions-xklass_1.10.20240726_all.ipk
- 17 Replies
- 2832 Views
- 84 Views
- 13 Replies
- 870 Views
- 205 Replies
- 61263 Views
Last post by Jack_Krauser777
- 17 Views
