New Update:29.06.2024
Changeset 11794 by BuSt3D
-Remove unused emu codes part 3
thanks @Bust3D
OsCam Changeset
New update: 01.07.2024
Changeset 11795 - f6c0ffb8
-add Dreambox Reader detection
thx Optimum Power
OsCam Changeset
New Update:01.07.2024
Changeset 11796 (dce7e760)
- add check EXTENDED_CW..
Thx @Opti
OsCam Changeset
Changeset 11797 (37b35822)
- Add support cwekey8 - cwekey16 for CAK7..
OsCam Changeset
Changeset 11799 (3b3944ec)
- add hide Provid-SA IRDID..
Thx opti
OsCam Changeset
New Update:02.07.2024
Changeset 1179x (3b3944ec)
- Fix zeros CW display on ecm.info file when streamrelay is in used. (Thanks to @cokeaddict)..
Thx @OhmZa
OsCam Changeset
New Update: 08.07.2024
Changeset 11800 (570851f3)
- Fix 'can't find 0xf0 in emm...' on Fransat V7 card (Thanks to @nitida and @OptimumPower)
OsCam Changeset
New Update:08.07.2024
Changeset 11801 (33fba234)
- Make webif compression optional..
Thx opti
OsCam Changeset
11802-7984f7b7
08.07.2024
Change webif compression parameter
* rename WEBIF_COMPRESS to WITH_COMPRESS_WEBIF (enabled by default)
* remove build warning: trigraph ??' ignored, use -trigraphs to enable [-Wtrigraphs]
thanks Optimum Power
OsCam Changeset
New Update:09.07.2024
Changeset 11803 (96debcd7)
Fix webif compression parameter
* remove -Wno-trigraphs flag for make/cmake..
* use 'XX' instead of '??' in javascript code..
* cleanup webif folder before each build..
* remove trailing newlines from html files..
* remove empty log line in cmake builds..
Display Less
Users browsing this forum: mehmetkarahanlı and 1 guest
