- Been thanked: 121 times
30
07:24
New Update:29.06.2024
Changeset 11794 by BuSt3D
-Remove unused emu codes part 3
thanks @Bust3D
thanks @Bust3D
01
13:18
OsCam Changeset
New update: 01.07.2024
Changeset 11795 - f6c0ffb8
-add Dreambox Reader detection
thx Optimum Power
thx Optimum Power
01
15:44
OsCam Changeset
New Update:01.07.2024
Changeset 11796 (dce7e760)
- add check EXTENDED_CW..
Thx @Opti
Thx @Opti
01
15:57
OsCam Changeset
Changeset 11797 (37b35822)
- Add support cwekey8 - cwekey16 for CAK7..
02
05:12
OsCam Changeset
Changeset 11799 (3b3944ec)
- add hide Provid-SA IRDID..
Thx opti
Thx opti
02
14:27
OsCam Changeset
New Update:02.07.2024
Changeset 1179x (3b3944ec)
- Fix zeros CW display on ecm.info file when streamrelay is in used. (Thanks to @cokeaddict)..
Thx @OhmZa
Thx @OhmZa
11:10
OsCam Changeset
New Update: 08.07.2024
Changeset 11800 (570851f3)
- Fix 'can't find 0xf0 in emm...' on Fransat V7 card (Thanks to @nitida and @OptimumPower)
14:36
OsCam Changeset
New Update:08.07.2024
Changeset 11801 (33fba234)
- Make webif compression optional..
Thx opti
Thx opti
09
05:15
OsCam Changeset
11802-7984f7b7
08.07.2024
Change webif compression parameter
* rename WEBIF_COMPRESS to WITH_COMPRESS_WEBIF (enabled by default)
* remove build warning: trigraph ??' ignored, use -trigraphs to enable [-Wtrigraphs]
thanks Optimum Power
08.07.2024
09
11:54
OsCam Changeset
New Update:09.07.2024
Changeset 11803 (96debcd7)
Fix webif compression parameter
* remove -Wno-trigraphs flag for make/cmake..
* use 'XX' instead of '??' in javascript code..
* cleanup webif folder before each build..
* remove trailing newlines from html files..
* remove empty log line in cmake builds..
Display Less
Display Less
- 50 Replies
- 4135 Views
- 9 Replies
- 198 Views
- 79 Views
- 50 Replies
- 7443 Views
- 23 Replies
- 4116 Views
