[E² Plugin] CoolExtra
Been thanked: 290 times
CoolExtra (Plugin for customizing CoolTVGuide V7.7 OE2.0)
MyFriendVTI wrote
With CoolExtra, the CoolTVGuide V7.7 OE2.0 plug-in can be customized as follows:
Button assignment / CoolInfoBox:
Plugin - TMDb
AEL-Editor (Advanced-Event-Library)
Plugin - Serial recorder
Plugin - AutoTimer (CoolInfoBox only)
Action: PVR/Video button
Action: Power button
CoolTVGuide customizations:
Center picons horizontally
Draw frame around picon
Deactivate limit picon line height
Scale line backgrounds
CoolInfoGuide customizations:
NextEvents: Move line content vertically (+/-)
CoolExtra does not change the installed CoolTVGuide plugin!
If no options are activated in CoolExtra or CoolExtra is uninstalled, the CoolTVGuide plugin can be used as usual in its original state.
Notes:
The red button cannot be assigned to a plug-in
If a plug-in has been assigned to a button with CoolExtra, this button cannot be reassigned in the CoolTVGuide settings.
Only when the button has been released again in the CoolExtra settings is reassignment possible again
If there is an AEL image in CoolTVEPG and the AEL editor is opened and closed, the CoolExtra log can be used to track which image files were searched for for the AEL image display
Thanks MyFriendVTI
enigma2-plugin-extensions-coolextra_1.0_all.rar
(18.01 KiB) Downloaded 87 times
Re: [E² Plugin] CoolExtra
Update-Info V1.1
Added: The event view from the system (program details) can be assigned to a button (e.g. to the EPG/Info button instead of the CoolInfoGuide)
In the CoolTVGuide, already recorded programs can optionally be highlighted, as in the GMEPG (small colored bar at the bottom) [prerequisite is the use of the VTi SQL database].
Thanks MyFriendVTI
enigma2-plugin-extensions-coolextra_1.1_all.ipk
(18.38 KiB) Downloaded 80 times
Update-Info V1.2
-The plugin TV-Spielfilm-Viewer can optionally be added to a button or to the CoolInfoBox to retrieve data about a selected program from TV-Spielfilm
Thanks MyFriendVTI
enigma2-plugin-extensions-coolextra_1.2_all.ipk
(18.71 KiB) Downloaded 34 times
