7-Zip file archiver
You Can Share Pc Softwares Windows exe etc...
7-Zip file archiver
7-Zip v24.03 (BeTa)
New Update:23.03.2024
    - 7-Zip now can use new RISCV filter for compression to 7z and xz archives.
    RISCV filter can increase compression ratio for data containing executable
    files compiled for RISC-V architecture.
    - The speed for LZMA and LZMA2 decompression in ARM64 version for Windows
    was increased by 20%-60%.
    - 7-Zip GUI and 7-Zip File Manager can ask user permission to unpack RAR archives that
    require big amount of memory, if the dictionary size in RAR archive is larger than 4 GB.
    - new switch -smemx{size}g : to set allowed memory usage limit for RAR archive unpacking.
    RAR archives can use dictionary up 64 GB. Default allowed limit for RAR unpacking is 4 GB.
    - 7zg.exe (7-Zip GUI): -y switch disables user requests and messages.
    - 7-Zip shows hash methods XXH64 and BLAKE2sp in context menu.
    - -slmu switch : to show timestamps as UTC instead of LOCAL TIME.
    - -slsl switch : in console 7-Zip for Windows : to show file paths with
    linux path separator slash '/' instead of backslash separator '\'.
    - 7-Zip supports .sha256 files that use backslash path separator '\'.
    - Some bugs were fixed.
Download 7-Zip v23.03)-(2024-03-23)
https://www.7-zip.org/download.html
Re: 7-Zip file archiver
7-Zip 24.04 beta (2024-04-05) ​
What's new after 7-Zip 24.03:​
New menu item in 7-Zip File Manager: "Tools / Delete Temporary Files...". This menu item opens a window showing temporary folders and files created by 7-Zip in the user's "Temp" folder on a Windows system. In this window, the user can delete temporary files.
Another packages and source code will be available later.
7-Zip v24.05
New Update:14.05.2024
- New switch -myv={MMNN} to set decoder compatibility version for 7z archive creating.
{MMNN} is 4-digit number that represents the version of 7-Zip without a dot.
If -myv={MMNN} switch is specified, 7-Zip will only use compression methods that can
be decoded by the specified version {MMNN} of 7-Zip and newer versions.
If -myv={MMNN} switch is not specified, -myv=2300 is used, and 7-Zip will only
use compression methods that can be decoded by 7-Zip 23.00 and newer versions.
- New switch -myfa={FilterID} to allow 7-Zip to use the specified filter method for 7z archive creating.
- New switch -myfd={FilterID} to disallow 7-Zip to use the specified filter method for 7z archive creating.
Download 7-Zip v24.05-(2024-05-14)
7-Zip v24.06
  New Update:26.05.2024
    - The bug was fixed: 7-Zip could not unpack some ZSTD archives..
Download 7-Zip v24.06-(2024-05-26)
Been thanked: 158 times
7-Zip file archiver
7-Zip v24.08
New Update:11.08.2024
HISTORY of the 7-Zip v24.07
- The bug in 7-Zip 24.00-24.08 was fixed:
For creating a zip archive: 7-Zip could write extra zero bytes after the end of the archive, if a file included to archive cannot be compressed to a size smaller than original.
The created zip archive is correct except for the useless zero bytes after the end of the archive.
When unpacking such a zip archive, 7-Zip displays a warning:
"WARNING: There are data after the end of archive".
- The bug was fixed: there was a leak of GDI objects (internal resources in Windows)
in "Confirm File Replace" window, causing problems after 1600 displays of "Confirm File Replace"
window from same running 7-Zip process.
- Some optimizations for displaying file icons in 7-Zip File Manager and in "Confirm File Replace" window.
