Page 3 of 3
Levi45 plugins update monitoring
Posted: 24 Jul 2024, 13:18
levi45 Addons Panel UPDATE 24-07-2024
enigma2-plugin-extensions-mmpicons_1.4_all.ipk
enigma2-plugin-extensions-xklass_1.08.20240723_all.ipk
enigma2-plugin-skins-aglare-fhd_3.8_all.ipk
enigma2-plugin-skins-maxy-fhd_1.1_all.ipk
enigma2-plugin-extensions-mmpicons_1.4_all.deb
enigma2-plugin-extensions-xklass_1.08_20240723_all.deb
Posted: 27 Jul 2024, 11:06
levi45 Addons Panel UPDATE 26-07-2024
enigma2-plugin-extensions-hdfradio_2.11.2_py2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py2_cortexa9hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.11.2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.11.2_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.11.2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.11.2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.12_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.12_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.12_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.2_py3_3.12_mips32el.ipk
enigma2-plugin-extensions-xklass_1.10.20240726_all.ipk
enigma2-plugin-extensions-youtube_h1-git1221-7b30012-r0.0.ipk
enigma2-plugin-extensions-youtube_py3-git1221-7b30012-r0.0.ipk
skins-metrixfhd-neo_oatv_V.7s_r5_all.ipk
enigma2-plugin-extensions-xklass_1.10_20240726_all.deb
Posted: 30 Jul 2024, 06:34
levi45 Addons Panel UPDATE 29-07-2024
enigma2-channellist-vhannibal-motor_29-07-2024_all.ipk
enigma2-channellist-vhannibal-motor-icam-levi45-mod_29-07-2024_all.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py2_cortexa9hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.11.2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.11.2_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.11.2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.11.2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.12_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.12_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.12_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.11.4_py3_3.12_mips32el.ipk
enigma2-plugin-extensions-eventdatamanager_all_v1.0-r20_.deb
Re: Levi45 plugins update monitoring
Posted: 31 Jul 2024, 05:57
by sugar
enigma2-plugin-extensions-levi45multicammanager_10.1-r23_all
Ipk/Deb file added, after installation if the plugin not showing in the plugin menu then please give this command
if you image is pyhon 3.xx then
if you image is python 2.xx then
Soon will be new release 10.1-r24
what's new
Cleaned unnecessary codes
Changed way that online update done(instead of auto update now you can update via pressing info and then yellow button to update ,if there is any newer version available)
Now you can remove installed cam, via Levi45 Multicam Manager , Cam Download (yellow button)
To install use command below :
wget -q "--no-check-certificate"
https://raw.githubusercontent.com/levi- ... staller.sh -O - | /bin/sh
Posted: 06 Aug 2024, 16:34
levi45 Addons Panel UPDATE 06-08-2024
enigma2-channellist-ciefp-vod-motor_05-08-2024_all.ipk
enigma2-plugin-extensions-coolextra_1.2_all.ipk
enigma2-plugin-extensions-linuxsat-panel_2.0_all.ipk
enigma2-plugin-extensions-piconremover_0.1-r1-20240806_all.ipk
enigma2-plugin-extensions-simple-zoom-panel_2.1.0_all.ipk
enigma2-plugin-extensions-linuxsat-panel_2.0_all.deb
Posted: 07 Aug 2024, 14:32
levi45 Addons Panel UPDATE 07-08-2024
enigma2-channellist-mohamedos-motor_07-08-2024_all.ipk
enigma2-plugin-extensions-levi45multicammanager_10.1-r26_all.ipk
enigma2-plugin-extensions-vavoo_1.24_all.ipk
enigma2-plugin-extensions-youtube_h1-git1224-3393574-r0.0.ipk
enigma2-plugin-extensions-youtube_py3-git1224-3393574-r0.0.ipk
enigma2-plugin-extensions-levi45multicammanager_10.1-r26_all.deb
enigma2-plugin-extensions-vavoo_1.24_all.deb
Posted: 08 Sep 2024, 12:06
Satellite-Forum.Com
levi45 Multicam Manager UPDATE 08-09-2024
enigma2-plugin-softcams-oscam-emu-levi45_11825-802_all.ipk
enigma2-channellist-ciefp-motor-abertis-arm_07-09-2024_all.ipk
enigma2-channellist-ciefp-motor-abertis-mips_07-09-2024_all.ipk
enigma2-plugin-softcams-oscam-emu-levi45_11825-802_all.deb
Satellite-Forum.Com
levi45 Addons Panel UPDATE 08-09-2024
enigma2-plugin-extensions-apod_1.1_all.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.11.2_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.11.2_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.11.2_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.11.2_mips32el.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.12_cortexa7hf-vfp.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.12_cortexa9hf-neon.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.12_cortexa15hf-neon-vfpv4.ipk
enigma2-plugin-extensions-hdfradio_2.13.7_py3_3.12_mips32el.ipk
enigma2-plugin-extensions-iptvarchive_2.0.85_all.ipk
enigma2-plugin-extensions-noipautologin_0.3-r0_all.ipk
enigma2-plugin-extensions-noipdyndns-modded_experimental-1.31_all.ipk
enigma2-plugin-extensions-xstreamity_4.58.20240907_all.ipk
enigma2-plugin-extensions-apod_1.1_all.deb
enigma2-plugin-extensions-iptvarchive_2.0.85_all.deb
enigma2-plugin-extensions-xstreamity_4.58_20240907_all.deb
Posted: 11 Sep 2024, 06:25
Satellite-Forum.Com
levi45 Addons Panel UPDATE 10-09-2024
enigma2-plugin-softcams-oscam-emu-levi45_11827-802_all.ipk
enigma2-plugin-extensions-apod_1.2_all.ipk
enigma2-plugin-skins-xDreamy_3.0.0_all.ipk
enigma2-plugin-softcams-oscam-emu-levi45_11827-802_all.deb
enigma2-plugin-extensions-apod_1.2_all.deb
levi45 Multicam Manager UPDATE 10-09-2024
