[E² Plugin] Wireguard-VPN
- Has thanked: 12 times
- Been thanked: 203 times
Re: [E² Plugin] Wireguard-VPN
Update Online WireGuard VPN V.11.9
* Fixed channel resume (streaming) if another server is started in Personal files.
* Added skin selection (Thanks for the Mmark skin).
* Updated the French translation (thanks gruick1).
Python 3.9 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .9_all.ipk
Python 3.11 (ARM - End of support): https://github.com/m4dhouse/Wi…ireguard ... .9_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .9_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wi…-vpn-aar ... .9_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wi…ard-vpn- ... .9_all.ipk
Update Online WireGuard VPN V.12.0
09.11.2024
* If the backup file has been created it asks with a PopUp if you want to import it.
* Added skin Grey.
* Updated the German translation (thanks Tommy007)
* Updated the Greek translation (thanks giorbak)
* Update .po and .pot files.
thanks madhouse
Python 3.9 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .0_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .0_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wi…-vpn-aar ... .0_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wi…ard-vpn- ... .0_all.ipk
09.11.2024
* Added skin Grey.
thanks madhouse
Update Online WireGuard VPN V.12.1
* Fix UnboundLocalError: local variable 'backup_dir' referenced before assignment (thanks gigafox72)
thanks madhouse
Python 3.9 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .1_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wi…ireguard ... .1_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wi…-vpn-aar ... .1_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wi…ard-vpn- ... .1_all.ipk
thanks madhouse
Update Online WireGuard VPN V.12.2
* Fixed installation of dependencies.
* Added sounds option.
* Added page numbering.
* Updated the German translation (thanks Tommy007 ).
* Updated the Greek translation (thanks giorbak ).
Download
Download
Update Online WireGuard VPN V.12.3
* Added more selectable sounds.
* Fixed the search for online updates if you are connected via VPN.
* Fixed key mapping.
* Update po and pot files.
Python 3.9 (ARM): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.11 (ARM - End of support): https://github.com/m4dhouse/Wireguard-V ... .9_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Update Online WireGuard VPN V.12.4
* Fixed the configuration for personal files, in some cases it did not show the Disconnect button.
* Fixed backup creation and restore for Mipsel boxes (Thanks foreverMiky64).
* Added Russian translation (Thanks airforce).
* Updated the German translation (thanks Tommy007).
* Updated the Greek translation (thanks giorbak).
Update Online WireGuard VPN V.12.5
* Added option to use sound in enigma2 (experimental) after exiting the plugin.
* Added another host to check IP, country and ping.
* Now using your personal files make 2 attempts to establish the tunnel.
* Small graphic changes, change of sound when opening the plugin.
* Added Russian translation (Thanks airforce ).
Python 3.9 (ARM): https://github.com/m4dhouse/Wireguard-V ... .4_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wireguard-V ... .5_all.ipk
Update Online WireGuard VPN V.12.6
* Added Ping Selected Server - All Servers - Disabled option.
* Small graphic changes.
* Updated Russian translation (Thanks airforce).
Python 3.12 (ARM): https://github.com/m4dhouse/Wireguard-V ... .6_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .6_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wireguard-V ... .6_all.ipk
Update Online WireGuard VPN V.12.7
* Fixed the connection time in case the box is completely rebooted.
* Added ping per page option.
* Fixed ping for selected server, it is not performed again on the same server.
* Fixed the DNS leak test, if you are not connected to the VPN it shows a message.
* Added support for the NonSoloSat image.
Python 3.9 (ARM): https://github.com/m4dhouse/Wireguard-V ... .7_all.ipk
Python 3.11 (ARM - Fine del supporto ): https://github.com/m4dhouse/Wireguard-V ... .9_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wireguard-V ... .7_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .7_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wireguard-V ... .7_all.ipk
https://github.com/m4dhouse/Wireguard-Vpn
Update Online WireGuard VPN V.12.8
* Speeded up pinging both by page and by selection.
* Removed the option to ping all servers, it was useless
* Fixed execution on the NonSoloSat image (thanks pippomus for testing).
* Added support for the CobraLiberoSat image (thanks pippomus for testing).
* Built and tested on Python 3.13.
GitHub
Python 3.9 (ARM): https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
Python 3.12 (ARM): https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
Python 3.12 (AARCH64): https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
Python 3.12 (MIPSEL): https://github.com/m4dhouse/Wireguard-V ... .8_all.ipk
GitHub
- 812 Views
- 123 Views
- 1335 Views
- 93 Replies
- 5417 Views
- 1420 Views
