NCam Emu by Shahrooz "NO CHAT"
- Has thanked: 14 times
- Been thanked: 315 times
ncam-gitb54bf83
sh4-linux-emu-ipv6 E2 sh4 CCcam.cfg Config
https://fastupload.io/a315813dbab68da1
sh4-linux-stapi-emu-ipv6 Xcruiser Nandhd/Openboxhd/Cuberevohd CCcam.cfg Config
https://fastupload.io/5536baad150cabd9
sh4-linux-stapi5-emu-ipv6 Xcruiser Avanthd/Openboxhd CCcam.cfg Config
https://fastupload.io/37d70d42caeee90c
x86_64-linux-gnu-webif-dvbapi-libdvbcsa-emu-ipv6-icam-neon ubuntu22.0 CCcam.cfg config
https://fastupload.io/401972b2aed293a1
x86_64-webif-dvbapi-libusb-webtouch-pc-cygwin pc-windows ncam.server/CCcam.cfg config
https://fastupload.io/5cbdf9b1c549b0c3
aarch64-dreambox-linux-gnu-pcsc-libdvbcsa-upx DreamBoxONE/TWO etc/tuxbox/config CCcam.cfg Config ssl3.3.2
https://fastupload.io/fc4f4034dda7cadb
mipsel-unknown-linux-gnu-pcsc-libdvbcsa-upx var/tuxbox/config CCcam.cfg Config Mipseloe2.0(DREAMBOX, VU+DUO2) ssl3.0.15
https://fastupload.io/7ae4151f031a5a30
--> While the moderator's away, the spammers will play <--
Re: NCam Emu by Shahrooz "NO CHAT"
ncam-sh1.1-git021c197 CCcam.cfg Config
sh1.1 = my compile serial
aarch64-dreambox-linux-gnu-libdvbcsa DreamBoxONE/TWO etc/tuxbox/config
armv7a-unknown-linux-android24-stapi Openbox AS4K CI Pro+, Xcruiser 4K Avant HDR, ICONE IRON Pro,... data/plugin/ncamcd
arm7a-vuplus4k-linux-gnueabihf-pcsc-libdvbcsa etc/tuxbox/config
arm7-vuplus4k-linux-gnueabihf-pcsc-libdvbcsa etc/tuxbox/config
arm-vuplus4k-linux-gnueabihf-pcsc-libdvbcsa etc/tuxbox/config
mipseoe2.0-unknown-linux-gnu-pcsc-libdvbcsa (dreambox, vu+) var/tuxbox/config
x86_64-linux-gnu-pcsc-libdvbcsa ubuntu22.0
https://fastupload.io/b90d77f52eb8a759
ncam-sh1.2-git9cf6a01 CCcam.cfg Config
sh1.2 = my compile serial
Add support Tongfang EMM
x86_64-webif-dvbapi-libusb-touchwebif-pc-cygwin pc-windows
ncam-sh1.4-gitf5a87db CCcam.cfg Config
webif: Create default webserver SSL certificate
* when webif configured to use https and no certificate file is present
* X.509 ECDSA certificates with V3 extensions are created by default (RSA certificates for OpenSSL versions before 1.1.0)
* new option https_auto_create_cert (default = enabled)
* show OpenSSL version in startlog when webif started in https mode
* detect target OpenSSL version and show it in build log (next to compiler version)
ncam-1.3-git6f70ac1-arm-v7a8v3r1-linux-gnueabi-ssl3.4.0 /mtd_rwcommon/oscam samsungtv ssl3.4.0
ncam-sh1.5-git357e79f CCcam.cfg Support
x86_64-webif-dvbapi-touchwebif-pc-cygwin pc-windows
- ncam-sh1.5-git357e79f-x86_64-pc-cygwin.zip
- (4.68 MiB) Downloaded 32 times
- ncam-sh1.5-git357e79f.zip
- (9.56 MiB) Downloaded 55 times
ncam-sh1.6-gitb9b9f35 CCcam.cfg Support
- ncam-sh1.6-gitb9b9f35-x86_64-pc-cygwin.zip
- (4.68 MiB) Downloaded 53 times
- 5 Replies
- 1189 Views
- 4 Replies
- 1066 Views
- 1 Replies
- 828 Views
- 2200 Views
- 685 Views
