Backup Vu+ Zero4K Open BlackHole 5.4.1
Has thanked: 12 times
Been thanked: 186 times
*** VU+ Zero 4K ***
*** Open BlackHole 5.4.1.010 ***
>>>> Full BACKUP by @Amos333 <<<<
7. January 2025
------- Hardware specifications --------
Receiver: Vu+ Zero4K
Tuner: DVB-S2X
Chipset: Broadcom 72604
CPU: ARMv7 1.5 Ghz Dual core
SoC: BCM72604
Memory: 4GB eMMC/2GB DDR4
LAN: 100 MBit/s
Video decoding: HVEC / H.265
------- Image specifications -----------
Image version: Open BlackHole 5.4.1
Image revision: 010
Architecture: cortexa15hf-neon-vfpv4
Drivers: 07-04-2021
Kernel version: 4.1.20-1.9
Gstreamer , version 1.22.12
Last update: 07-12-2024
Python version: 3.12.4
Start video resolution: 1920x1080p
Default language: English (US)
Network configuration: Automatic - DHCP
Tuner configuration: Simple - Positioner - USALS
Start motor position: Astra 19,2E
USALS coordinates: 20.5E - 44.8N (Belgrade, Serbia)
Channel list: @ciefp -E2-80E-34W-14.12.2024 motor & IPTV list
Start channel: IPTV Q Music (NL)
The Weather plugin location: Belgrade , Serbia
Skin: MX Maestra Blue FHD
------- Button Hotkey configuration ---------
Blue: CAM manager
Blue Long press: Extension menu
TXT: Raed Quick Signal Infobar
Right arrow: AJPanel Terminal
------- Telnet access ----------
Username: root
Password: amos333
-------- Installed plugins -----------
Panels:
AJ Panel
EliesatPanel
Linuxsat Panel
TiVuStream Addon Panel
SimpleZOOMPanel
Multi-Stalker PRO
StalkerClient TV
Jedi Maker Xtream
Jedi EPG Xtream
XCplugin
XStreamity
XKlass
Filebrowser
DLNA/uPnP Browser
Chromium OS
Dream-Explorer
DreamPLEX
E2iPlayer
CrossEPG Downloader
EPG-Importer
Openmultiboot
Ciefp Settings Downloader
FootOnSat
HasBahCa
IMDB & TMBD search
Internet Speed Test
Permanent Clock
Pluto TV
RakutenTV
SamsungTVPlus
Vavoo Stream Live
Radio M
RAED Quick Signal
MAC changer
SubsSupport DVB Player
SubsSupport downloader
Uninstaller
Tetris
The Weather
YouTubeTV
Installed drivers:
ntfs3g
exFAT
Softcam tools:
Oscam & NCam Status
FreeServer
KeyAdder
Installed softcam:
CCcam 2.3.9
NCam 15.2 by MOHAMED_OS
OSCam 11865-r802 by MOHAMED_OS
SoftCam.Key, CCcam.cfg by @MOHAMED_OS
Keys stored in: /etc/tuxbox/config/
NOTICE:
- Video resolution setup is enabled on very first boot
- Startup channel is IPTV so you can set your USALS coordinates before you use motor list
(MENU -- Setup -- Tuners & Scanning -- Tuner Setup -- OK -- enter your coordinates -- SAVE -- EXIT)
- PermanentClock ON/OFF : Menu -- Setup -- System -- PermanentClock -- Deactivate/Activate
full-backup_OpenBH_5.4.1_VUzero4K_07Jan2025.zip/file
[SHOW POST]
https://www.mediafire.com/file/qisfua8p ... 5.zip/file
