[E² Plugin] MultiStalker-Pro
- Been thanked: 289 times
Mar 2024
29
05:31
enigma2-plugin-extensions-multi-stalkerpro_1.1+git47
Fixed bug on watchlist.
enigma2-plugin-extensions-multi-stalkerpro_1.1+git47+d764d630+d764d63d92-r0_cortexa15hf-neon-v...ipk (2.56MB)
https://www.sendspace.com/file/r4vuwy
Apr 2024
03
05:23
Re: [E² Plugin] MultiStalker-Pro
PY3.12 ARM for VIX/OBH
- built-in missing gui components
this ipk is only for this two images.
enigma2-plugin-extensions-multi-stalkerpro_1.1+git142+3c917ef0+3c917ef553-r0_cortexa15hf-neon-...ipk (2.88MB)
https://www.sendspace.com/file/lkbtc8
Apr 2024
04
06:27
enigma2-plugin-extensions-multi-stalkerpro_1.1+git144+4ef83e7-r0_mips32el
OPENPLi develop image only
python3-rarfile_4.1-r0_mips32el.ipk (31.49KB)
https://www.sendspace.com/file/epmvol
python3-levenshtein_0.12.0-r0_mips32el.ipk (24.14KB)
https://www.sendspace.com/file/nopa9x
python3-fuzzywuzzy_0.18.0-r0_mips32el.ipk (9.03KB)
https://www.sendspace.com/file/swl2fo
enigma2-plugin-extensions-multi-stalkerpro_1.1+git144+4ef83e7-r0_mips32el.ipk (1.92MB)
https://www.sendspace.com/file/h7mypc
May 2024
04
06:44
May 2024
05
04:54
May 2024
06
06:52
May 2024
30
07:47
OPENPLI DEVELOP
- enigma2-plugin-extensions-multi-stalkerpro_1.1+git165+24295f8-r0_armv7ahf-neon.ipk
- (1.98 MiB) Downloaded 87 times
- python3-rarfile_4.1-r0_armv7ahf-neon.ipk
- (31.49 KiB) Downloaded 104 times
- python3-levenshtein_0.12.0-r0_armv7ahf-neon.ipk
- (20.7 KiB) Downloaded 85 times
- python3-levenshtein_0.12.0-r0_armv7ahf-neon-1.ipk
- (20.7 KiB) Downloaded 98 times
- python3-fuzzywuzzy_0.18.0-r0_armv7ahf-neon.ipk
- (9.03 KiB) Downloaded 98 times
May 2024
31
07:21
VIX/OBH
AARCH64
AARCH64
- enigma2-plugin-extensions-multi-stalkerpro_1.1+git165+24295f80+24295f8904-r0_aarch64.ipk
- (2.73 MiB) Downloaded 93 times
- python3-rarfile_4.1-r0_aarch64.ipk
- (58.48 KiB) Downloaded 90 times
Jun 2024
04
06:29
A beta test for arm (ATV/PURE/EGAMI)
- Add support for xtream subscriptions
- Add a web interface to add/remove or edit a portal and also you can add your api keys from the web interface
The structure of MultistalkerPro.json had been changed so you need to add again you protals trough the web interface and its better to empty the MultistalkerPro.json file
you can access the web interface with the same ip of webinterface following with /multi-stalkerpro/portals
for example my box ip is: 192.168.1.88 so the web interface url is
http://192.168.1.88/multi-stalkerpro/portals
- enigma2-plugin-extensions-multi-stalkerpro_1.1+git92+9846d680+9846d68c94-r0_cortexa15hf-neon-v...ipk
- (2.76 MiB) Downloaded 129 times
Jun 2024
05
04:48
V1.2
- Fix EPG
- Prevent memory leaks caused by some channels picons by limiting the resolution to 1280x720
- Enable series special season if available
- Fix navigations in portals selection with pure2 image
- Update translation files
- Major improvements and bug fixes
Only for arm devices and for (atv/pure/egami) Python3.12.2/3.12.3.
- Fix EPG
opkg install --force-depends /tmp/*.ipk
- enigma2-plugin-extensions-multi-stalkerpro_1.1+git94+247e9ab0+247e9ab8e1-r0_cortexa15hf-neon-v...ipk
- (2.79 MiB) Downloaded 103 times
