The program can:
download defined channel lists,
upload oscam on a clean system, regardless of the platform,
update oscam without knowing what it is on,
in the configuration you can change the selected oscam between 4 editions Jej@n, Jej@n ICAM, samur, MOHAMED_OS/kitte888
the ability to run scripts from the command line
throw out GS from time to time....
auxiliary tools have been created in the additional tools tab, which are constantly being expanded:
information about the currently used oscam,
backup oscam settings,
backup channel lists
make a picon copy,
restore data from a copy, but in the case of oscam, the current configuration location is checked first and restored there, so you can transfer your settings between different distributions.
upload current oscam.srvid2 (requires manual oscam restart to take effect)
upload current satellites.xml (requires manual oscam restart to take effect)
remove root password,
setting the need for a password when logging in to ftp (which is disabled by default in most distributions), also removes the root password,
changing the webif oscam port to 8888,
show permissions of local cards,
and many others
it speaks 3 languages PL/EN/DE but is gettext so pot file included
s4aUpdater
- 75 Views
