[Plugin] HistoryZapSelector
Has thanked: 78 times
Been thanked: 27 times
Post by ocean777 »
UPDATE 1.0.39
1) Added search for channels by occurrence of a given string in their title. Called by long pressing the yellow button on the remote control... Very convenient if you use VOD playlists to find the movie you want
enigma2-plugin-extensions-historyzap_1.0.39_all.rar
(1.74 MiB) Downloaded 124 times
Re: [Plugin] HistoryZapSelector
Post by ocean777 »
UPDATE 1.0.40
1) Minor changes in the algorithm for searching for similar channel names or searching for the occurrence of a string in a channel name. Now works much faster, more accurately, and with less memory consumption
2) The base ConfigSelection class has been redesigned. If your image supports displaying graphics in the selection options of the settings window, then you will display icons instead of phrases. This modification also works on any DreamOS-based images. For example, this functionality can be “evaluated” on OpenPli, OpenBH, Merlin, GP4, etc. images.
enigma2-plugin-extensions-historyzap_1.0.40_all.rar
(1.74 MiB) Downloaded 115 times
Post by ocean777 »
UPDATE 1.0.41
1) Fixed a bug with the inability to select the key-file from the root directory
2) Minor code optimization
enigma2-plugin-extensions-historyzap_1.0.41_all.rar
(1.74 MiB) Downloaded 94 times
pavelparal
Has thanked: 1 time
Been thanked: 17 times
Czech Republic
#4
Post by pavelparal »
UPDATE 1.0.43
1) Fixed EPG translation language selection in plugin settings for GP4.2 image for DM ONE and TWO (possibly also for any other E2-images in which country flag icons are set in SVG format)
2) Added check for required renderers and converters for DreamOS-based images, if they are not present in the image being used, they will be automatically added.
enigma2-plugin-extensions-historyzap_1.0.43_all.rar
(1.79 MiB) Downloaded 21 times
