New Update:15.04.2024
Fixed vulnerabilities:
-SFTP: Fixed PuTTY ECDSA NIST P-521 private key recovery vulnerability (CVE-2024-31497). If you use NIST P-521 keys to connect to SSH/SFTP servers, you should regenerate them and revoke the previous ones.
FileZilla Latest Version
- Has thanked: 77 times
- Been thanked: 28 times
FileZilla Client is 3.67.0
- Been thanked: 293 times
Re: FileZilla Latest Version
FileZilla Server v1.8.2 Released
Download FileZilla Server v1.8.2
New Update:26.04.2024
FileZilla Server now requires that the configuration directory is owned either by the operating system user account the server runs under, or a more privileged user (SYSTEM, Amdministrators, TrustedInstaller on Windows, root elsewhere)
MSW: Mount points are now case-insensitive so that restrictions on sub mounts cannot be bypassed by a change of character case..
Bugfixes and minor changes:
Fixed a potential deadlock during transfers..
FTP: Fixed potential crash if the session gets closed..
FileZilla Client v3.67.1-rc1 Released
Download FileZilla Client
New Update:27.06.2024
- Fixed an issue migrating old queue files if several older versions have been skipped..
- Updated to libfilezilla 0.48.0..
FileZilla Client v3.67.1 Released
New Update:10.07.2024
- MSW: Fixed an issue with confirmation dialogs for file deletion not being modal..
- Updated to libfilezilla 0.48.1..
- Been thanked: 157 times
FileZilla Server v1.9.0-rc1 Released
New Update:08.08.2024
New features:
- Private keys used for TLS can now be stored on a PKCS#11-compatible token device; the UI has been updated accordingly.
- UI: added button to retrieve the current FileZilla Server's public IP address, useful to configure the PASV mode.
- UI: added an FTP connection test, that can be reached directly from the Server menu item or executed at the end of the FTP Network Configuration Wizard.
- Made default values more secure, among which: require TLS on new FTP listeners, require a password for new users and warn if the administration password doesn't meet more stringent security requirements.
- Fixed bug causing the most recent log file, rather than the oldest, to be deleted upon rotation, when using dates as suffixes.
- MSW: fixed regression causing socket listener conflicts due to recent libfilezilla changes.
- Added WebUI: an HTTP server providing a REST API and a web app for seamless web access to stored files. WebUI is not included in the default build and must be enabled with the --enable-webui parameter during compilation. This feature is experimental; feedback and bug reports are welcome.
- UI: the certificate fingerprint verification dialog is now sized to display the full fingerprint at once.
- UI: fixed bug causing the focus to be lost during user editing.
- UI: fixed bug causing the tray icon to display unexpectedly in certain cases.
- UI: improved error handling in case of server disconnection.
- UI: improved handling of Settings window size on ultra wide screens.
- FTP: the MKD command now returns an error if the directory already exists.
- FTP: Improved login timeout handling to exclude internal server processing time.
- Fixed heap corruption in the Administrator Interface.
- Fixed regression in the path handling routines.
New features:
FileZilla Server v1.9.0 Released
New Update:05.09.2024
- MSW: Warn if installing the server outside of Program Files due to custom directories having too lax permissions..
- Fixed a race condition resulting in stalled connections..
- *nix: Fixed a potential crash if SIGINT is sent to the server while it is shutting down..
- Fixes to the update check mechanism..
- Fixed a regression in the converter for old 0.9.x configurations dealing with placeholders in native paths.
Download
Download
FileZilla Server v1.9.1 Released
New Update:09.09.2024
- Fixed a regression introduced in 1.9.0, the "public IP or hostname" field on the passive mode page was not restored when opening the settings dialog
Download
Download
FileZilla Server v1.9.2 Released
New Update:30.09.2024
- Fixed an issue with the update mechanism..
Download
Download
FileZilla Server v1.9.3 Released
New Update:17.10.2024
- Fixed a regression causing the automatic renewal of the Let's Encrypt® certificates to not work properly..
- UI: fixed regression causing the Administration Interface port of the last successful connection to not be properly restored..
- UI: fixed a bug where the TLS key appeared to be lost in the interface if certificate generation failed, even though the key was still retained on the server..
Download
Download
FileZilla Client v3.68.0-rc1 Released
New Update:18.10.2024
New features:
Added option to always refresh remote directory listings when starting a recursive operation..
- Changing logfile settings no longer requires a restart of FileZilla..
- Fixed a display issue with special characters in usernames..
- MSW: Fixed local file list not updating after renaming or deleting items..
- SFTP: Update interval of transfer progress during uploads should now be more consistent on very slow connections..
- Updated to libfilezilla 0.49.0..
Download
New features:
Download
- 18 Views
- 33 Replies
- 3454 Views
Last post by kalpikos
- 1271 Views
- 22 Replies
- 1950 Views
- 5 Replies
- 764 Views
