[Plugin] IPTVArchive
Has thanked: 77 times
Been thanked: 28 times
Post by ocean777 »
Update IPTV Archive Ver 2.0.78
-Fixed stream request format for some IPTV providers
-Changed the pause algorithm for standard Enigma2 stream "players" (1:, 4097:, 8739:)
Thx @ Pepsik
enigma2-plugin-extensions-iptvarchive_2.0.78_all.rar
(2.03 MiB) Downloaded 95 times
Re: [Plugin] IPTVArchive
UPDATE 2.0.80
The ability to select the source of “depth” of archived records has been added to the plugin settings. The following options are available:
a) 'from the playlist' - in this case, the 'depth' values of archived recordings will be taken from the values of the corresponding tags of the playlist used. If the playlist does not have tags responsible for the “depth” of the archives, then the default values are specified in the plugin code for the IPTV provider you used.
b) 'by default' - the 'depth' of days for archived broadcasts will be obtained from the default values set for your IPTV provider in the plugin code
c) 'user defined' - the 'depth' of days for archived broadcasts will correspond to that specified by the user. The specified value will apply to all IPTV providers. With this setting, you will receive a list of archived broadcasts to the depth you specify, but whether there will be broadcasts when requested from the provider’s servers is determined only experimentally.
2.0.79
1) The logic for working with alternative APIs has been modernized for greater cross-compatibility between different IPTV providers
2) The logic for searching archived broadcasts by channel name has been modified if they are not found in the specified APIs
3) German localization fixed
enigma2-plugin-extensions-iptvarchive_2.0.80_all.rar
(2.05 MiB) Downloaded 83 times
UPDATE 2.0.81
1) Fixed a crash that occasionally occurred when FF/RW or exiting the view using the "exit" button
2) Added caching of API requests/responses to reduce the number of unnecessary calls
enigma2-plugin-extensions-iptvarchive_2.0.81_all.rar
(2.06 MiB) Downloaded 99 times
#4
Post by ocean777 »
IPTV Archive Ver 2.0.82
1) Fixed a bug with the inability to select the key-file from the root directory
2) Minor code optimization
enigma2-plugin-extensions-iptvarchive_2.0.82_all.rar
(1.03 MiB) Downloaded 79 times
#5
Post by ocean777 »
IPTV Archive Ver 2.0.83
enigma2-plugin-extensions-iptvarchive_2.0.83_all.rar
(1.03 MiB) Downloaded 17 times
#6
Post by ocean777 »
IPTV Archive Ver 2.0.84
Code changes and modifications to improve stability with supported APIs
enigma2-plugin-extensions-iptvarchive_2.0.84_all.rar
(1.04 MiB) Downloaded 25 times
Been thanked: 157 times
#7
UPDATE
2.0.85
1) Small code optimization for Cbilling and Antifriz
2) Fixed a bug that resulted in not receiving the list of archived broadcasts when selecting “archives depth” - “default” or “user-defined in plugin settings
3) Fixed UK locale
thanks Dorik1972
enigma2-plugin-extensions-iptvarchive_2.0.85_all.ipk
enigma2-plugin-extensions-iptvarchive_2.0.85_all.deb
(1.03 MiB) Downloaded 16 times
#8
Post by ocean777 »
UPDATE
2.0.86
enigma2-plugin-extensions-iptvarchive_2.0.86_all.rar
(1.04 MiB) Downloaded 17 times
#9
UPDATE
2.0.87
1) Fixed crash when calling playback of archive broadcast on OBH 5.4.1
enigma2-plugin-extensions-iptvarchive_2.0.87_all.ipk
(1.04 MiB) Downloaded 10 times
enigma2-plugin-extensions-iptvarchive_2.0.87_all.deb
(1.04 MiB) Downloaded 6 times
