WireGuard VPN by Madhouse
Posted: 25 May 2024, 07:55
* Currently supports the following images: Egami, OpenAtv, OpenVix, PurE2, Openblackhole, OpenPLi, OpenHdf (python 3.9 - 3.11 - 3.12)
* Supports (for now) Surfshark, NordVpn, ProtonVpn, MullvadVpn, IVpn providers and personal files.
* Requires the Private Key issued by your vpn provider (downloadable via the provider's website)
* The Private key must be copied and pasted in the file located in /etc/Privatekey.key or /media/hdd/WgConfig/Privatekey.key or /media/usb/WgConfig/Privatekey.key
* To import the key you need to run Wireguard Vpn, green button (Settings) Blue button - Load Private Key
* If you want to use the bypass function, remember to save and then connect to a server.
INFO.
Wireguard Vpn plugin is not compatible with OpenVpn, if OpenVpn is running, you have to stop OpenVpn (if a startup setting is active at boot, you have to disable it), you have to reset the Gateway (router ip) in the network configurations.
WireGuard VPN requires dependencies that are installed by the plugin.
wireguard-tools - wireguard-tools-bash-completion - openresolv - kernel-module-wireguard - iptables (for the kill switch).
What's new in version 10.0
* Added Kill Switch.
* [NordVpn] Retrieving the private key from nordlynx via access token (https://support.nordvpn.com/hc/en-us/ar ... N-on-Linux)
* Small graphic changes.
If you get a crash while using it, post the crashlog FTP: /home/root/logs
Python 3.9: https://github.com/m4dhouse/Wi…ireguard ... .0_all.ipk
Python 3.11: https://github.com/m4dhouse/Wi…ireguard ... .0_all.ipk
Python 3.12: https://github.com/m4dhouse/Wi…ireguard ... .0_all.ipk
How i get my private Key of my nord vpn account
INFO.
