PHILIPS Sonicare Electric Toothbrush DiamondClean, Rechargeable Electric Tooth Brush with Pressure Sensor, Sonic Electronic Toothbrush, Travel Case, Pink
About this item
Up to 7x better plaque removal vs manual electric toothbrushes - Sonicare electric toothbrush with advanced sonicare technology is clinically proven to remove up to 7x better* plaque from your teeth and along the gum line while protecting your gums.
Pressure Sensor helps protect your teeth and gums - Built-in pressure sensor automatically detects pressure you apply, warns you, and reduces the toothbrush vibrations automatically to help protect your gums. The toothbrush will make a pulsing sound as a reminder to ease off the pressure. 7 out of 10 people found this feature helped them become better brushers.
Our unique technology brings you a powerful yet gentle clean - Powerful bristle vibrations drive microbubbles deep between your teeth and along your gum line for a refreshing experience. You will get two month's worth of manual brushing in just 2 minutes. 31000 brush strokes per minute gently clean your teeth, break up plaque, and sweep it away for an exceptional daily clean.
buy link
https://amzn.to/4cz25eZ
