5.0.240626
Minor improvement:
- although the use of SNP picons is not very popular, due to their partial support in the plugin, it was necessary to change the search algorithm of all available satellite packages
- picon designer chocholousek will now be able to add some other SNP picon packs to the database (but they are still not primarily used in the plugin)
thanks s3n0
ChocholousekPicons Updater (E2 plugin)
- Been thanked: 293 times
Jun 2024
26
14:34
- enigma2-plugin-extensions-chocholousek-picons_5.0.240626_all.deb
- (125.46 KiB) Downloaded 25 times
- enigma2-plugin-extensions-chocholousek-picons_5.0.240626_all.ipk
- (125.46 KiB) Downloaded 29 times
Jun 2024
27
05:03
Re: ChocholousekPicons Updater (E2 plugin)
for those who want these are the telnet commands to remove the old version and install the new one but be careful it resets the profile
wget -qO- --no-check-certificate "https://github.com/s3n0/e2plugins/raw/master/ChocholousekPicons/online-setup" | bash -s uninstall
wget -qO- --no-check-certificate "https://github.com/s3n0/e2plugins/raw/master/ChocholousekPicons/online-setup" | bash -s install
- Has thanked: 8 times
- Been thanked: 121 times
Sep 2024
03
17:26
5.0.240903
Minor improvement:
- in case of a problem receiving an HTML file instead of a 7zip file, the found HTML title from the file will be displayed
- fixed wrong resolution, in case of alternate image "image_not_found.png"
Minor improvement:
- enigma2-plugin-extensions-chocholousek-picons_5.0.240903_all.ipk
- (125.61 KiB) Downloaded 13 times
- enigma2-plugin-extensions-chocholousek-picons_5.0.240903_all.deb
Please use only "Like Button", no need to write thank you
Sep 2024
03
17:28
5.0.240904
BUG fix:
File "/usr/lib/enigma2/python/Components/ScrollLabel.py", line 58, in setText
TypeError: in method 'eLabel_setText', argument 2 of type 'std::string const &'
- this was a string conversion issue between C++ and Python, in Enigma2 - Gemini Project 4.2
- thx to Warder for the BUG report and for testing the BUG fix in Gemini
BUG fix:
- enigma2-plugin-extensions-chocholousek-picons_5.0.240904_all.ipk
- (125.76 KiB) Downloaded 14 times
- enigma2-plugin-extensions-chocholousek-picons_5.0.240904_all.deb
- (125.76 KiB) Downloaded 13 times
- 67 Views
- 1111 Views
- 48 Replies
- 4324 Views
- 1221 Views
- 1700 Views
