Xtream Codes IPTV Player (new)
- Has thanked: 8 times
- Been thanked: 107 times
Jul 2024
08
05:14
X Klass - Official Release
V 1.00 - 07/07/2024
Plugin is for playing official Xtream Codes/XUI ONE IPTV playlists.
This plugin is a rework of XStreamity plugin but with all new layout and new side menu accessible by the "Menu" button.
This plugin does not play other playlists or m3u playlists.
I work non stop on my plugins. It's hard work. If you like my work and you want me to continue, you can always show your appreciation by buying me a beer
Github Repository - Git is updated as soon as a release is bug free and stable
https://github.com/kiddac
Do not post personal MOD code in this thread, including different functionality, different skins etc. It confuses me, it confuses users.
Also we test most code on multiple images and boxes. Modifications might work on your setup, but may crash other peoples.
Start a new thread if need be quoting it is a mod and what images/box it is has been tested on.
This plugin does not contain any playlists or channels. All IPTV playlists need to be sourced by user.
IPTV is perfectly legal - IPTV providers/playlists that contain unscrambled encrpyted channels are illegal.
User is responsible for any downloaded playlist content.
We do not discuss IPTV providers on this forum.
I don't recommend, promote or have an affiliation with any provider. Questions regarding IPTV providers will be ignored/deleted.
Do not post IPTV provider names, provider URLs, provider IP addresses, or screenshots that identify providers in this thread.
Check any posted crash logs do not contain any of your provider, username & password details.
It is recommend you use a VPN with any IPTV plugin. VPN use is not the topic of this thread.
XKlass should be compatible with all images and boxes.
Installation
XKlass is available in lots of image feeds under plugins / download plugins / extensions. The 100% latest version can always be found on post 1 of this thread.
Feeds are sometimes a little behind. (note this is a brand new plugin - feeds will catchup)
openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies.
Then you can load the latest from this forum over the top.
How to manually install .ipk on OE-Alliance images via telnet
To manually install, copy ipk to tmp folder
then telnet/ putty
opkg install /tmp/*.ipk
How to manually install .deb on DreamOS via telnet
then telnet/ putty
dpkg -i /tmp/*.deb
apt-get update
apt-get install -f
press Y key to finish installation when asked
Dependencies
In the majority of cases the plugin will automatically install all the required dependencies required for XKlass.
Rarely this fails and the user will need to ensure all dependencies are installed currently via telnet/putty
If you are getting repeated dependencies console screen. Try these commands
Python 2
opkg install python-requests
opkg install python-multiprocessing
opkg install python-image
opkg install python-imaging
opkg install wget Full wget is required for https lines and used by the download manager.
python 3
opkg install python3-requests
opkg install python3-pillow
Dreamboxes
apt-get -y install python-requests
apt-get -y install python-image
apt-get -y install python-imaging
apt-get -y install wget Full wget is required for https lines and used by the download manager.
python3
apt-get -y install python3-requests
apt-get -y install python3-multiprocessing
thanks KiddaC
V 1.00 - 07/07/2024
Installation
then telnet/ putty
then telnet/ putty
dpkg -i /tmp/*.deb
apt-get update
apt-get install -f
Dependencies
Python 2
python 3
Dreamboxes
python3
thanks KiddaC
- enigma2-plugin-extensions-xklass_1.00_20240707_all.deb
- (5.1 MiB) Downloaded 26 times
- enigma2-plugin-extensions-xklass_1.00.20240707_all.ipk
- (5.34 MiB) Downloaded 30 times
Please use only "Like Button", no need to write thanks
Jul 2024
08
05:16
XKlass v1.01
Fixed python 2.7 crash
thanks KiddaC
thanks KiddaC
- enigma2-plugin-extensions-xklass_1.01_20240707_all.deb
- (5.1 MiB) Downloaded 28 times
- enigma2-plugin-extensions-xklass_1.01.20240707_all.ipk
- (5.34 MiB) Downloaded 21 times
Jul 2024
08
05:18
XKlass v1.02
fixed a multiprocessing crash on some barebones images
thanks KiddaC
thanks KiddaC
- (5.1 MiB) Downloaded 21 times
- Has thanked: 76 times
- Been thanked: 28 times
Jul 2024
10
06:18
Re: Xtream Codes IPTV Player (new)
v.1.03
Tnx.KiddaC
Tnx.KiddaC
- enigma2-plugin-extensions-xklass_1.03.20240709_all.rar
- (5.34 MiB) Downloaded 29 times
Jul 2024
18
08:00
XKlass - Official Release.
V 1.04 - 15/07/2024
Fixed the crash if default playlist is not active or not responding - playlists screen should now show instead.
Blue button functionality returns on the start menu - to delete the working json data files - Use when things are going weird.
Code tweak to how and when custom sids (satellite refs) for epgs are picked up.
Removed blank epg importer source file. Not needed. It gets built if required.
Translation updates for spain, china and germany.
New intro video selection option - for those users putting alternative videos in the video folder.
Slight tweak to the logic of determining if a playlist has been switched or not.
V 1.04 - 15/07/2024
- enigma2-plugin-extensions-xklass_1.04_20240715_all.deb
- (5.1 MiB) Downloaded 24 times
- enigma2-plugin-extensions-xklass_1.04.20240715_all.ipk
- (5.34 MiB) Downloaded 22 times
Jul 2024
18
08:01
V 1.05 - 16/07/2024
Fixed the start menu loop if one of the urls was failing. Now correctly looks for 1 valid url, not all valid urls
Added asterisks into channel name clean ups
Added Chinese language option for TMDB data
Slight update to Italian translation
V 1.05 - 16/07/2024
- enigma2-plugin-extensions-xklass_1.05_20240716_all.deb
- (5.1 MiB) Downloaded 20 times
- enigma2-plugin-extensions-xklass_1.05.20240716_all.ipk
- (5.34 MiB) Downloaded 24 times
Jul 2024
19
05:14
V1.06 - experimental release
Just added a couple of default sort options for VOD. (not live or series)
I got this terrible wrong last time I did this so lets see if this is any better.
- enigma2-plugin-extensions-xklass_1.06_20240718_all.deb
- enigma2-plugin-extensions-xklass_1.06.20240718_all.ipk
Jul 2024
23
16:37
XKlass v1.07
Update German Translations
Relaxed the rules around json content. It was a little strict.
- enigma2-plugin-extensions-xklass_1.07_20240723_all.deb
- (5.1 MiB) Downloaded 19 times
- enigma2-plugin-extensions-xklass_1.07.20240723_all.ipk
- (5.34 MiB) Downloaded 25 times
Jul 2024
24
05:27
XKlass v1.08
Series episode duration should now show correctly if available, whether TMDB turned on or of
- enigma2-plugin-extensions-xklass_1.08_20240723_all.deb
- (5.1 MiB) Downloaded 14 times
- enigma2-plugin-extensions-xklass_1.08.20240723_all.ipk
- (5.34 MiB) Downloaded 18 times
Jul 2024
26
05:15
XKlass - Official Release - The Final Frontier.
V 1.10 - 26/07/2024
Fix for older images missing twisted web client BrowserLikePolicyForHTTPS
thanks KiddaC
V 1.10 - 26/07/2024
thanks KiddaC
- enigma2-plugin-extensions-xklass_1.10_20240726_all.deb
- enigma2-plugin-extensions-xklass_1.10.20240726_all.ipk
- (5.34 MiB) Downloaded 17 times
- 20 Replies
- 3004 Views
- 6 Replies
- 164 Views
- 14 Replies
- 944 Views
Last post by ocean777
- 228 Replies
- 66065 Views
Last post by Jack_Krauser777
- 36 Views
