X Klass - Xtream Codes IPTV Player (new)
afat45
SW FEED HUNTER
SW FEED HUNTER
Has thanked: 7 times
Been thanked: 28 times
Turkey
Aug 2024 25 13:13
Post by afat45
XKlass - Official Release - The Final Frontier.
V 1.11 - 25/08/2024 :face with monocle:
Plugin is for playing official Xtream Codes/XUI ONE IPTV playlists.
This plugin is a rework of my XStreamity plugin but with all new layout and new side menu accessible by the "Menu" button.
This plugin does not play other playlists or m3u playlists.
I work non stop on my plugins. It's hard work. If you like my work and you want me to continue, you can always show your appreciation by buying me a beer.
:beer1: https://paypal.me/kiddac :beer1: or :hot beverage: https://ko-fi.com/kiddac :hot beverage:
https://github.com/kiddac
Do not post personal MOD code in this thread, including different functionality, different skins etc. It confuses me, it confuses users.
Also we test most code on multiple images and boxes. Modifications might work on your setup, but may crash other peoples.
Start a new thread if need be quoting it is a mod and what images/box it is has been tested on.
This plugin does not contain any playlists or channels. All IPTV playlists need to be sourced by user.
IPTV is perfectly legal - IPTV providers/playlists that contain unscrambled encrpyted channels are illegal. User is responsible for any downloaded playlist content.
We do not discuss IPTV providers on this forum.
I don't recommend, promote or have an affiliation with any provider. Questions regarding IPTV providers will be ignored/deleted.
Do not post IPTV provider names, provider URLs, provider IP addresses, or screenshots that identify providers in this thread.
Check any posted crash logs do not contain any of your provider, username & password details.
It is recommend you use a VPN with any IPTV plugin. VPN use is not the topic of this thread.
XKlass should be compatible with all images and boxes.
Installation
XKlass is available in lots of image feeds under plugins / download plugins / extensions. The 100% latest version can always be found on post 1 of this thread.
Feeds are sometimes a little behind. (note this is a brand new plugin - feeds will catchup)
openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies. (Xstreamity plugin in feeds will also load the dependencies)
Then you can load the latest from this forum over the top.
How to manually install .ipk on OE-Alliance images via telnet
To manually install, copy ipk to tmp folder
then telnet/ putty
opkg install /tmp/*.ipk
How to manually install .deb on DreamOS via telnet
then telnet/ putty
dpkg -i /tmp/*.deb
apt-get update
apt-get install -f
press Y key to finish installation when asked
Dependencies
In the majority of cases the plugin will automatically install all the required dependencies required for XKlass.
Rarely this fails and the user will need to ensure all dependencies are installed currently via telnet/putty
If you are getting repeated dependencies console screen. Try these commands
Python 2
opkg install python-requests
opkg install python-multiprocessing
opkg install python-image
opkg install python-imaging
opkg install wget Full wget is required for https lines and used by the download manager.
python 3
opkg install python3-requests
opkg install python3-pillow
Dreamboxes
apt-get -y install python-requests
apt-get -y install python-image
apt-get -y install python-imaging
apt-get -y install wget Full wget is required for https lines and used by the download manager.
Dreamboxes - python3
apt-get -y install python3-requests
apt-get -y install python3-multiprocessing
enigma2-plugin-extensions-xklass_1.11_20240825_all.deb.rar
(5.1 MiB) Downloaded 18 times
enigma2-plugin-extensions-xklass_1.11.20240825_all.rar
(5.34 MiB) Downloaded 17 times
afat45
SW FEED HUNTER
SW FEED HUNTER
Turkey
Aug 2024 26 05:07
Re: X Klass - Xtream Codes IPTV Player (new)
Post by afat45
V 1.12 - 25/08/2024
enigma2-plugin-extensions-xklass_1.12_20240825_all.deb.rar
(5.1 MiB) Downloaded 17 times
enigma2-plugin-extensions-xklass_1.12.20240825_all.rar
(5.35 MiB) Downloaded 18 times
Has thanked: 76 times
Sep 2024 08 14:17
Post by ocean777
V 1.13 - 08/09/2024
enigma2-plugin-extensions-xklass_1.13.20240908_all.rar
(5.35 MiB) Downloaded 14 times
Sep 2024 15 04:41
Post by ocean777
#4
V 1.14 - 14/09/2024
tnx KiddaC
enigma2-plugin-extensions-xklass_1.14.20240915_all.rar
(5.37 MiB) Downloaded 14 times
Has thanked: 8 times
Been thanked: 148 times
Sep 2024 15 10:29
Post by Hannibal_Lecter
#5
V 1.15 - 15/09/2024
enigma2-plugin-extensions-xklass_1.15_20240915_all.deb
(5.11 MiB) Downloaded 11 times
enigma2-plugin-extensions-xklass_1.15.20240915_all.ipk
(5.37 MiB) Downloaded 11 times
Please don't ask or send me anything via PN
Sep 2024 23 15:32
#6
XKlass v1.16
updt_21-09-2024
Redirect fixes
Expired line crash fix
Greece, Italy, Portugal Language transaltion updates
enigma2-plugin-extensions-xklass_1.16_20240921_all.deb
enigma2-plugin-extensions-xklass_1.16.20240921_all.ipk
Sep 2024 27 05:36
#7
XKlass v1.17
I think I have fixed that tmdb variable crash
Also added in a few more amends for stripping out of some prefixes to help names work better with tmdb searching
enigma2-plugin-extensions-xklass_1.17_20240926_all.deb
(5.11 MiB) Downloaded 14 times
enigma2-plugin-extensions-xklass_1.17.20240926_all.ipk
afat45
SW FEED HUNTER
SW FEED HUNTER
Turkey
Oct 2024 31 04:59
Post by afat45
#8
V 1.18 - 30/10/2024 :face with monocle:
enigma2-plugin-extensions-xklass_1.18_20241030_all.deb.rar
(5.11 MiB) Downloaded 1 time
enigma2-plugin-extensions-xklass_1.18.20241030_all.rar
(5.37 MiB) Downloaded 2 times
