[Free Cccam] [E² Plugin] my_KCCCAM
Daily free cardsharing servers
SATWORLD
Has thanked: 838 times
Been thanked: 133 times
Contact:
Post by SATWORLD »
Here is my new plugin for Python 2.7.
It is a single server generator.
It generates only one server per day for one IP address!
After installation, turn the plugin on and then off again. This will populate it.
Then, turn it back on. There will be an example shown on the screen.
Press OK. Use the blue button to switch to numbers on the keyboard.
Enter the number (the result of the example). Save with the green button.
In a moment, it will either show that it was unsuccessful or that it was successful along with the server line.
Please be patient. It may not work the first time. Try it multiple times.
Attention: This plugin cannot restart CAM. I have it set to simple (ncam) without a number.
It only converts for Oscam, Ncam...
Restart the CAM and check if you have the new server.
If the plugin reports "...no module named...", use the following commands.
opkg update
opkg install python-lxml
opkg install python-requests
killall -9 enigma2
my_KCCCAM_all.ipk
(25.98 KiB) Downloaded 31 times
Always Press Thanks Button :D
