DimitarCC wrote
This is new plugin that aims to fix the problems with management of IPTV sources.
Can be downloaded from image feed (except OpenATV for which manual install is needed)
For ATV you have to download the zip from github and manually copy the things in the box.
What plugin can do:
- Generate bouquets based on provided playlist (separated by the groups/categories)
- Supports dynamically changing playlists (when stream URL contains hashes changed periodically)
- Import EPG if specified in the playlist or provider (Xtream Codes)
- Import EPG from custom URL (requires EPG Import plugin)
- Download picons if defined in the playlist/provider
- Use catchup/archive if specified in the playlist/provider
- Supports M3U/M3U8, Xtream Codes, Stalker (only live TV)
- Play VoD if available from the provider
- Deeply integrated to the system so there is no difference in look and feel than normal enigma (use existing channel lists, EPG, MoviePlayer)
What images are supported:
- OpenViX and all its derivatives
- OpenBH and all its derivatives
- OpenPLi Develop only and all its derivatives
- OpenATV 7.5 only (the catchup/archive there not work since their EPG screens differs and cant be supported yet.). Manual install is needed!!!
Source code can be found here M3UIPTV Github (https://github.com/DimitarCC/iptv-m3u-reader)
Enigma2 Plugins M3UIPTV
- Been thanked: 157 times
- 34 Replies
- 1753 Views
- 7 Views
- 102 Replies
- 7185 Views
Last post by kalpikos
- 19 Replies
- 3428 Views
Last post by ocean777
- 64 Replies
- 5451 Views
