Page 1 of 1
X Klass - Xtream Codes IPTV Player (new)
Posted: 25 Aug 2024, 13:13
by afat45
V 1.11 - 25/08/2024 :face with monocle:
This plugin is a rework of my XStreamity plugin but with all new layout and new side menu accessible by the "Menu" button.
:beer1: https://paypal.me/kiddac :beer1: or :hot beverage: https://ko-fi.com/kiddac :hot beverage:
Feeds are sometimes a little behind. (note this is a brand new plugin - feeds will catchup)
openpli 8.3+ / openpli 9 please install from plugin feeds first to load required dependencies. (Xstreamity plugin in feeds will also load the dependencies)
Dreamboxes - python3
Re: X Klass - Xtream Codes IPTV Player (new)
Posted: 26 Aug 2024, 05:07
by afat45
V 1.12 - 25/08/2024
Posted: 08 Sep 2024, 14:17
by ocean777
V 1.13 - 08/09/2024
Posted: 15 Sep 2024, 04:41
by ocean777
V 1.14 - 14/09/2024
tnx KiddaC
Posted: 15 Sep 2024, 10:29
V 1.15 - 15/09/2024
Posted: 23 Sep 2024, 15:32
XKlass v1.16
updt_21-09-2024
Redirect fixes
Expired line crash fix
Greece, Italy, Portugal Language transaltion updates
Posted: 27 Sep 2024, 05:36
XKlass v1.17
I think I have fixed that tmdb variable crash
Also added in a few more amends for stripping out of some prefixes to help names work better with tmdb searching
Posted: 31 Oct 2024, 04:59
by afat45
V 1.18 - 30/10/2024 :face with monocle:
